Hi
I am using a simple java web service to return the object
containing a string and an integer using e4x format. The result I
get in the result event is
"<ns:return type="read.Profile" xmlns:ax21="
http://read/xsd" xmlns:ns="
http://read" xmlns:soapenv="
http://schemas.xmlsoap.org/soap/envelope/"/>".What i am unable to understand is where is the object that
the service would have returned???
Another question is can we return arraylist from the
webservice?? If i try to add the objects into the array list and
pass it into the flex application, i get an " HTTP request error".
Please advise.
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml"layout="absolute">
<mx:WebService id = "ReadData" wsdl="{'
http://localhost:8080/ReadData/services/ReadQuickbase?wsdl'}"fault="Alert.show(event.fault.faultString)" showBusyCursor="true"
useProxy="false">
<mx:operation name ="returnData" resultFormat="e4x"
result= "showItemResult(event)">
<mx:request xmlns="">
<shared>
</shared>
</mx:request>
</mx:operation>
</mx:WebService>
<mx:Script>
<![CDATA[
import mx.collections.ArrayCollection;
import mx.rpc.events.ResultEvent;
import mx.controls.Alert;
[Bindable]
private var resultdata:ArrayCollection;
private namespace read = "
http://read/"; use namespace read;
public function sendRequest():void {
ReadData.returnData.send();
private function showItemResult(res:ResultEvent):void {
var _xml:XML;
_xml = XML(res.result);
</mx:Script>
<mx:Button x="273" y="64" label="getIT" click=
"sendRequest()"/>
<mx:Label x="190" y="81" id="myLabel"/>
</mx:Application>
Java web service
package read;
import java.util.ArrayList;
import java.util.Set;
import java.util.Vector;
import java.util.HashMap;
class Profile {
String name;
int age;
void setvalues(String name, int age) {
this.name = name;
this.age = age;
public class ReadQuickbase {
public Profile returnData() {
Profile p = new Profile();
try {
p.setvalues("abc", 10);
catch (Exception e){
e.printStackTrace();
return p;
