2 Replies Latest reply on Mar 22, 2018 5:38 AM by pziecina
    IE 11 - scripts or activeX
    annikaf67731523
      Dear All
      I created a internal website for out team with muse. Sadly standard browser is internet explorer.
      When I want to open the site i get this message: "internet explorer has restricted this webpage from running scripts or activeX controls"
      Is there any possibility to solve that problem?
      I already Implemented the following Metadata: <meta http-equiv="X-UA-Compatible" content="IE=11" />
      But that didn't solve the problem.
      Can anyone help?
      And is it possible to choose the browser via code?
      Thanks for helping.
      KR Annika
        • 1. Re: IE 11 - scripts or activeX
          ankushr40215001 Level 7
          Hey Annika,
          It's a warning, not an error - it's Microsoft trying to protect your computer from local HTML files.
          Your client should not see the message if the site is on a web server.
          If they do, it tells that the server is a file server or a different configuration.
          You may add the below note when hen distributing the site link so the viewer can disable the warning.
          Go to Internet Options > Advanced Tab and scroll down to security.
          Tick Allow Active Content to run in files on My Computer.
          Hope this helps!
          Regards,
          Ankush
          • 2. Re: IE 11 - scripts or activeX
            pziecina Level 6
            To add to the reply by Ankush.
            It is o/k to use javascript in IE11 but on no account should you have anything that requires active-x. The reason for this is because by the end of 2020 Microsoft will remove the ability completely from IE11 to run active-x.
            Along with any flash content.
            2 people found this helpful
