5 Replies Latest reply on Mar 23, 2018 12:47 PM by D Fosse
    Camera Raw Filter shows different colors
    pedroschg5
      Hello,
      i am using Photoshop CC 2018 19.1.0 with Camera Raw 10.2.1.895
      When i open an RGB file in Photoshop and then apply the Camera Raw filter from the filters menu, the picture in the Camera Raw dialog looks more saturated, than in photoshop.
      The Colormangement setting in Photoshop an Camera Raw are equal also i am using a calibrated Eizo CG277 High End monitor.
      Any suggestions?
      Thanks Peter
        • 1. Re: Camera Raw Filter shows different colors
          Warunicorn Adobe Community Professional
          Is Proof Colors on in Photoshop? (View > Proof Colors on the menu bar)
          • 2. Re: Camera Raw Filter shows different colors
            D Fosse Adobe Community Professional & MVP
            Are you using two monitors?
            This sounds very much like a problem that is occasionally reported in ACR "proper" (the raw converter plugin). What happens is that ACR uses the wrong monitor profile in a dual monitor setup. With the wrong profile, the wrong numbers are sent to screen. - and if one of them is wide gamut it really becomes obvious.
            The only workaround I know of is to change primary <> secondary display assignment in the OS.
            • 3. Re: Camera Raw Filter shows different colors
              pedroschg5 Level 1
              No because its an RGB file
              • 4. Re: Camera Raw Filter shows different colors
                pedroschg5 Level 1
                @ D Fosse
                Thanks for the quick answer. Your answer helped me to solve the problem.
                Here is what i did.
                I use 2 monitors with different monitorprofile for each one. In Windows Systemsettings>Colorsettings when i click on identify monitors my main monitor (witch i use as main monitor for Photoshop) with monitorprofile A, appears as 2. The second monitor (for Photoshop windows) with monitorprofile B appears as 1. Photoshop correctly uses profile A, identifyed as monitor 2, to display the files. But camera raw uses monitorprofile B, from the second monitor, identifyed as monitor 1, to display the file in camera raw. If i drag the camera raw window to the second monitor the files look equal, when i drag it back to my main monitor there is a difference. To solve the problem i set the monitorprofile A from my main monitor also on the second monitor. Then the Photoshop and camera raw shows the same with no difference. The only problem now is that the second monitor has a wrong monitorprofil, but i use this monitor only for photoshops windows, so it does not matter.
                I tryed a few things, that windows colorsettings identyfies my main monitor as 1 and not as 2. But did not find anything that works. I think the only way to do this is swap the connections on the graphic board. But that means i must calibrate both monitor new.
                Thanks Peter
                • 5. Re: Camera Raw Filter shows different colors
                  Thanks for confirming. This very problem comes up at regular intervals, so it clearly qualifies as a bug. But whether the bug is in ACR or the OS, or both, is impossible to say. I have never seen any official acknowledgement from Adobe.
                  Well, you should do that from time to time anyway.
