I'm trying to consume a webservice that requires an X.509
certificate. The webservice uses SOAP.
In our current setup, we already consume several SOAP
webservices. The way I usually do it is to create a XML Packet
where I manually generate the envelope, and then pass it using
CFHTTP.
I am having problems with this technique as I need to
generate the SOAP headers based off the binary tokens created by
the certificate.
I am never able to get anywhere using cfinvoke. I can never
even access the WSDL, which is why I always lean towards using
CFHTTP.
Does anyone know of any way to use a java object to access
the certificate and then output the tokens? I have already imported
the certificate into the cacerts keystore using the CF keytool
utility.
Thanks in advance,
Michael
