Hello,
I am setting up an Agreement Template in Salesforce and I am attempting to add a file from the Echo Sign library, however there are no documents showing available to add. However I have 7 templates in the Echo Sign library.
This is the first time I am attempting to integrate Salesforce and Echo Sign, and I am thinking it might be a connection issue?
Any help would be appreciated.
thank you
Monica
Hi Monica,
Did you figure out what the issue was? I too experience this?
Any information appreciated
regards
Conor
Hi Monica,
Did you set up the link between SalesForce and EchoSign (in SalesForce) ?
Regards,
Romain.
in relation to mine, yes i did but only some users can see the document templates
I am also facing the same issue
Greetings!
To expose the Adobe Sign library templates in your Salesforce installation, make sure to enable Show Adobe Sign Library Attachments in the Adobe Sign Custom Settings section.
If the account is correctly configured and linked to Adobe Sign, that is the only setting you need to change in Salesforce to expose the option for accessing the Adobe Sign library templates.
