In one of my projects I created multiple buttons. All the buttons have zero opacity and they all have a hint function with text that i use as a tooltip.
When i export my project to "HTML5 only" and test the buttons the tooltips are blinking and they are unreadable.
Does someone knows how i can fix this or is there any workaround?
How did you test? You have to publish and upload to a webserver to see the full functionality. Is it a responsive or a normal project?
Hi Lilybiri,
It is a normal project and i tested it on a LMS platform.
I never tried that out, just leave everything about hovering out of my projects with HTML output. Since you talk about a normal project, not about projects for mobile devices, use Rollover captions or Rollover shapes instead of the hint captions. I know that they will be mentioned by the HTML tracker, but in most cases they will play fine in desktop browsers.
