I have four images that, for some reason, won't publish to my Smugmug account from Lightroom. I know that the images are linked to Lightroom because if I export them, I have no problem. But when I try to publish I get a message for just these four images that says "Some expert operations were not performed" and then there's a dialog box that says "Not Found" and lists the files. I've had no problems uploading other images to the exact same Smugmug library. Any ideas?
It turns out, the problem was not that the images were unlinked in the catalog. That was my assumption as well. The problem was in sync’ing with SmugMug. And the tech support at SmugMug helped me resolve the problem. Thanks for your reply, though!
"Not Found" means Lightroom cannot find the photos. There is probably an exclamation point icon on the photos (or question mark icon if you have an older version of LR). You need to find the photos using your operating system, and then connect Lightroom to these photos as explained in this document: Adobe Lightroom - Find moved or missing files and folders
