Hey Guys,
im using Illustrator for a couple of years now, but i still cant handle two problems:
1. i have most times a problem when i want to overwrite my File, especially with huge files.
the error says something like this "This file is read-only or already in use by another user[...]"
I can only save it when i "save as.." and give another name to the file.
(Here the Error - in german language)
2. When im looking for a good font, the "font picker" is always starting with A (See Picture below).
No matter if the name of the Font i have selected begins with another Letter.
I wish my selected font would be the first in the list, when i select it and i can continue looking for the next fonts.
Is there any setting to change this?
Hope someone know, how to fix my problems.
Greetings,
Jan
1: Where do you save the file and which system is it?
2: no. Please use: http://illustrator.uservoice.com
Hi, the file is saved directly on my HDD. Im using Win 10 64-Bit.
Then please check your access privileges.
Hi there,
I would like to know if the suggestions shared above worked for you, or the issue still persists.
Kindly update the discussion if you need further assistance with it.
Srishti
