Hi there,
I would like to set up Global preferences for the Recording defaults so when I start a brand new Record a Simulation I have the customized captions.
I believe the Recording defaults go with the Theme, so if I create a project, then apply the Theme, I can see the customized Recording defaults.
However, if I open a brand new Record a simulation, I see the default Recording preferences.
Is there a way to apply the Recording defaults from a Theme to the Global Recording defaults?
Thanks in advance
Bobby
Did you try to export Preferences, if you cannot apply the same theme. Normally all settings in the Preferences can be exported and imported in new projects. Because Recording Defaults are also part of the 'design', they are also included in the Theme.
Thank you for your reply Lieve, I think this is on a different level. Exporting the preferences will allow me to import them in an existing project. When one starts a new Software simulation, there is no project per se. The new Software simulation would automatically take the Global recording defaults. Actually, I am not sure the Recording defaults are exported with the Preferences. They are part of the Theme, not of the Preferences. I may be wrong of course
Thanks again B
Must confess that I didn't test it, didn't have time - my bad and not what I normally do. You meay be correct because those choices use default styles which can be changed when switching to another theme. Maybe some one else can help you. Software simulations only use the Blank master slide. Do you use captions or shapes? What exactly do you want to preserve in all future projects?
I am using a custom made Smart shape and a highlight box mostly. Actually, what I did is the following
1. Ctr+R to start a new Simulation
2. Before shooting anything went to Settings
3. I go to the Recording / Defaults and tried to "Create New style". I thought maybe I should just recreate my custom styles in the Global preferences.
The software crashed and this is what I have now as Global Preferences: Recording: Defaults.
Nothing... Something went terribly wrong...
Thanks Lieve
Looks like your Preferences may have been corrupted when Captivate crashed. You will need to reset your Preferences.
Thanks Rod
I tried to "Restore Defaults" but Captivate crashes.
Is that what you mean?
No. Resetting your Preferences file involves digging down to the Captivate install directory in Program Files, find the Utils directory there, then double-click the CleanPreferencesWin.bat file.
Thanks Rod
I would need to involve other people since there are some restrictions. I will keep you posted.
Hi there Rod
I did reset the Preferences but I have the same issue
Would you have any tip for me?
Maybe should reinstall Captivate 2017?
Thanks once again
B
It's possible you may need to reinstall. But the issue you are seeing with items not appearing in the Preferences is normally solved by resetting Preferences.
If you DO reinstall Captivate, you'll also need to reset Preferences again there as well.
Thank you once again Rod
This is not a show-stopper for me right now, but I would need to consider reinstall.
Hello! Long shot that you are still waiting on an answer to this Bobby Jourdan​, but I may have a solution. We've been working with our own custom themes and using default object styles this year. I found that setting your theme (which has the desired object styles programmed) as your default theme will then enable you to apply those (now default) object styles to your Global Recording Preferences.
There are multiple threads related to setting a theme as the default. Depending on whether it's a custom theme or "out-of-the-box" theme you're using, you may want to consider saving your theme in a specific location. That is another conversation though...
Setting a Theme as Default: With a project open that is using the theme (and object styles) you want to use in your project, click Themes (button) > locate the theme you're using or want to use > right-click > select Set As Default Theme.
Applying the default object styles to new projects and recordings:
Open Global Preferences dialog: Close any projects you have open > click Edit (menu) > select Preferences.
Under Recording > Defaults, you should be able to access the object styles that are used in your default theme. Under Recording > Modes, you can then add the objects to your recording modes as you prefer.
Be careful. You are showing the new Themes dialog box, where you can hape multiple themes in one project. I am still exploring in-depth the consequences of this change. Recording defaults are indeed part of a theme, but what will happen in a project with multiple themes? Need more time, have figured out already several things, but not everything is clear. Same with Global Preferences which alos have Recording defaults, which could be overridden if you change to another theme.
Ha, yes, this new feature is getting added just when I start to learn about themes and object styles. It's making it a bit more difficult, for sure. And I'm definitely looking forward to reading what you find out!
I happened to stumble across this thread looking for something else, but since this workflow seems to work for our purposes I wanted to share.
Note: We are using a default custom theme to capture our screens for software simulations. Setting it as default theme allows us to access the objects we want from Global Prefs, for recording purposes. BUT...our process has always been to then take those captures and paste into another project (which actually uses a second custom theme). So, this "multiple themes in one project" thing is really going to be important for us to understand moving forward.
Thanks Lilybiri​!
Did you read my blos about Themes, Object Styles?
I sure have! I've read the entries listed below, as well as numerous forum threads, blogs of others...
I'm always reading something about Captivate, and your name is on a lot of them.
Object Styles in a Theme - Captivate blog
What's in a Theme - a Template? - Captivate blog
Captivate 8.0.1 Install? Keep your Customisation! - Captivate blog
You missed some (I don't see much published about Themes and Object styles)
Manage the Object Style Manager! - Captivate blog
Responsive Projects: Object styles - Captivate blog
Theme mysteries? - Captivate blog
Using Copy/Päste Appearance in 11.5.0 - Captivate blog
The last one has also some links with object styles as you will read....
Now I am busy with a blog about the changes for themes in 11.5.
Will get out of the way.
