Hey guys,
I need to create a custom rename script that will duplicate selected files and remove some characters(could vary from 9 to 10) from the end of the name and replace it with 1
So it looks like this now : NBSIACBGT-BKL-1 COPY.psd
And I need it like this : NBSIACBGT-1.psd
I already managed to do it through regular bridge using this regular expression : .{9}(\..{1,})$
I just need to add it into a script so I can call it out of a keyboard shortcut if that make sens to you guys.
Thank you !
Would this work?
...#target bridge
if( BridgeTalk.appName == "bridge" ) {
var cSelected = new MenuElement("command", "Copy selected", "at the end of Tools","cFiles");
cSelected.onSelect = function () {
var sels = app.document.selections;
var count = app.document.selectionsLength;
for(var a =0;a<count;a++){
var newName =decodeURI(app.document.selections.spec.name).match(/[^-]*/);
var ext = decodeURI(app.document.selections.spec.name).match(/\..+$/);
app.document.selections.spec.copy(app.document.presentationPath+ "/" +newName+"-1"+ext);
Random thoughts…
How do you assign a keyboard shortcut to a script in Bridge?
As I can’t script, It would likely be quicker and easier for me to do this through the operating system rather than in Bridge. If this is something that you would like to try at the OS level rather than Bridge, what OS are you?
I am unsure of your regex, as you say it may need to remove between 9-10 characters from the end… What is the pattern of your filenames and is it consistent? Can you provide more than one example of varied filenames?
Would it simply be easier to work from the start and stop at the first hyphen character, if that matches the pattern (rather than work backwards by a variable amount)?
Find: (^.+?-)(.+?)(.[^\.]+$)
Replace: $1$3
or
Find: (^.+?-)(.+)
Replace: $1
EDIT: The following topic is also related to your post, however it was never answered –
Hi Stephen,
I'm working on Siera V 10.12.6
If I could have this procedure scripted under Tools in Bridge, I can go to System Preferences - Keyboard - Shortcuts - App shortcuts, and call my script from there...does that make sense ?
I just need to have this working in a script.
Something that would be like this :
- duplicate all the WHATEVERCODEIS-BL-1.psd / WHATEVERCODEIS-WH-1.psd / WHATEVERCODEIS-OR-1.psd
- delete everything till WHATEVERCODEIS- keeping the extension and the - after the code
- add an 1
Thank you !
Would this work?
#target bridge
As usual, great work SuperMerlin! I can’t believe it only took 13 lines of code, hah!
I hope that works for joshuab, I had my doubts about the filenames, usage etc…
Example, it is OK to run this on file LOMSPCHTJ-OR-1.psd – however what if it was run on file LOMSPCHTJ-OR-2.psd, it would create a duplicate as both files would be renamed to LOMSPCHTJ-1.psd! SuperMerlin has accounted for this in his script, however I would have thought that this command would potentially be used with multiple images, not just one.
Fantastic ! It's exactly what I was looking for .
Works perfect on single and multiple files.
I guess I have to start learning javascript. Can you guys give me some tips where to start ?
Thank you very much SuperMerlin !
Greetings from Germany
You could download and install Adobe ExtendScript Toolkit
https://helpx.adobe.com/creative-cloud/kb/creative-cloud-apps-download.html
This is the development enviroment tool.
In the help section you will find the JavaScript Tools Guide pdf
Also download the Software Development Kits where you will find more documentation and examples.
Bridge SDK
https://console.adobe.io/downloads/br
Photoshop SDK
https://www.adobe.com/devnet/photoshop/sdk.html
Then there are the forums, if you can't find an answer ask, you will get a lot of help.
https://forums.adobe.com/community/photoshop/photoshop_scripting/content
https://forums.adobe.com/community/bridge/bridge_scripting/content
Good luck!
