How do I change the "fill and sign" function so that "place signature" puts my cursive signature on the document? Right now it puts my printed name and a certification onto the document
Hi Polarbear,
What try67 mentioned above is related to digital signatures and is correct.
For Fill and Sign, you may check this help page: Fill and sign PDF forms using Adobe Acrobat Fill & Sign
Feel free to update the discussion if you have further questions.
-Tariq Dar
You can add a new appearance to your signature profile that contains an image with your "wet" signature.
Click to sign the document and select the profile you want to use. Then click the Appearance drop-down and select "Create new appearance...". Under title enter something like "Hand-written signature" and then change the "Show" option to "Imported Graphic", and click the "File..." button to select the image of your signature. Set the rest of the settings and you're done:
Once you use it it will become the new default when you use that profile.
Hi Polarbear,
-Tariq Dar
