1 Reply Latest reply on Jul 2, 2008 6:41 AM by SujitG
    Blaze DS with Weblogic
    davidbaker29
      Hi
      I'm adding a Flex front-end to an existing J2EE application. In production the app is deployed as an Ear file in Weblogic 9.2. I've added the BlazeDS war file into this Ear file and deployed it successfully to Weblogic 9.2.
      In my development environment I deploy both the ear file and the blaze war file it contains in exploded format. This means that in Flex Builder 3 Pro, if I go to Project Properties -> Flex Server, I can set the 'root folder' property equal to the root of my exploded Blaze war file. Similarly in the Flex Compiler section of Project Properties, I can set the -services argument equal to the path to my services-config.xml file. This allows me to hook my Flex front-end to my Java classes in the ear file.
      But in production I'll need to deploy my app as an ear file and package Blaze as a war file within it. How then can I set the root folder and the path to my services-config.xml file? It won't be possible to browse to the files as they're bundled in the war file.
      David
        • 1. Blaze DS with Weblogic
          SujitG Level 2
          You need not add entire BlazeDS war file. You just have to include the required jar files of BlazeDS, all the jar files in WEB-INF/lib folder of the BlazeDS war are the required files to be added into your web application. Also you need to create a folder WEB-INF/flex in your web application and create services-config.xml and other configuration files as in WEB-INF/flex folder in the BlazeDS war file.
          Regarding the path to your services-config.xml. This file is compiled into your Flex application when you compile it. If you can look at the compiler arguments of your Flex project you can find the path to the services-config.xml.
          If you want you can create the services-config.xml file in any location and point to it in the compiler arguments. If you do this make sure the end point URLs are hard coded in the services-config.xml are proper and also there should be one services-config.xml file in the WEB-INF/flex folder of your web application for the BlazeDS/LCDS to use it to open up ports.
          When you point to your web applications root directory for the Flex builder, Flex Builder will use this location to load the services-config.xml and when you give the context-root etc, these will be used to replace the tokens in curls bracket in your services-config.xml so that the URL to send a request to your web application is formed based on the data you entered in the new project dialogue of Flex Builder.
          Hope this helps.
