3 Replies Latest reply on Apr 5, 2018 3:42 PM by Birck
    Can't open older PS files. Recommendations for Recovery software?
    Birck Level 1
      I'm on a Mac Pro, running OS10.13.3, and using PSCC2018. I'm an illustrator, and I use my older work as fodder for new jobs, assuming I can get at it. In most cases I can, but I have one large folder on an archive disk that won't yield up any of its contents. That's regardless of file type or age. Some are ca. 2006, 2009, or newer. The problem seems to be confined to this one folder. I have two other MacBooks, so I may be able to equip one with an older version of OS10 and/or an older Photoshop version, if necessary. Can anybody suggest a way to rescue these images?
        • 1. Re: Can't open older PS files. Recommendations for Recovery software?
          D Fosse Adobe Community Professional & MVP
          I don't think an old PS version will do anything one way or another - but OTOH you have nothing to lose, so by all means try it.
          Opening old files is almost never a problem. I have files dating back much longer than that, and have never seen any problems.
          More likely the folder has been corrupted in some way. Try to copy some files individually over to another machine, and see if they'll open there. Or can't you get into the folder at all? In that case it's an OS thing.
          • 2. Re: Can't open older PS files. Recommendations for Recovery software?
            josephlavine Adobe Community Professional
            I suggest removing applications from the equation, and simply seeing whether you can open the folder to review the contents.  If you can't open the folder then the folder might be corrupt, or you could have a permissions issue.
            If the folder opens and you can view the contents, then I suggest try opening from within an application.  Ie:  File>Open
            • 3. Re: Can't open older PS files. Recommendations for Recovery software?
              Birck Level 1
              messrs Fosse & Lavine: I tried that and it didn't work. I tried opening the files with Photoshop, Sketchbook Pro, and even -ugh-Preview. Even Preview couldn't open them. They were in a folder shifted from a previous disk, now stashed on a 6TB archive disk, and that folder alone was inaccessible. Everything around it: No problem. So I sprung for a photo recovery app that sort of works. I'm not going to name it because it has some problems. But it does recover the images. Once I find out whether the problems I have with it are due to my own ineptitude, or, rather, that the app is a buggy kludge, I'll send an update. Thanks, anyway, for considering the problem. These forums are always my first resource.
