0 Replies Latest reply on Jun 20, 2008 10:08 AM by raymond_domingo
    Flex Trees Webservices and Java
    raymond_domingo
      Hello,
      I'm trying to fill my flex tree using the data returned from my webservice...
      My Webservice is called findPersons and returns an array of persons (containing firstName and lastName properties).
      When I add myService.findPersons.lastResult as the dataProvider of my tree I just see Object in my tree, after adding the labelFunction attribute to my tree I could specify the firstName from the object should be used as my label. This is exactly what I need. The code looks like:
      private function readLabel(item:Object):String {
      return item.firstName;
      BUT, when my tree contains two types of objects, let's say objects of type:
      - person
      - adress
      Is there any way I can find out the type of the object. So in java I have Person and Address, but as far as I see in Flex I can't retrieve the java's object type. I would like to do something like:
      I know I can use resultFormat="e4x" but then I have to do all the handling my self and I don't bennefit from my Java object structure.
