• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
Cross dissolve not working
Engaged ,
Mar 28, 2018 Mar 28, 2018
I have a Cross Dissolve at the end of a clip and one at the end of the previous clip but only one is working.
I tried several transitions at this location and none of them seem to be working.  I have transitions between other clips in this sequence and they are working, so what's going here?
Views
22.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Mar 28, 2018 Mar 28, 2018
One of the first things to check with cross-dissolve issues is do you have the necessary 'handles' on the clip ends at that editing point?
A 'handle' is extra frames either past or before the edit point ... for the clip in front, that would be extra frames past the cut; for the clip behind the cut, extra frames in front of the cut.
If you don't have handles, there's nothing to dissolve ...
Neil
Votes
Translate
Translate
LEGEND ,
Neil
Votes
Translate
Translate
Report
Report
Engaged ,
Mar 29, 2018 Mar 29, 2018
Oh, that makes sense!  What I did was cut the clip and add a transition.
Thanks!
Votes
Translate
Translate
Report
Report
Community Expert ,
The cross dissolve is working alright but you are not seeing anything as its using the same frames (handles) as the clip.
There is no point in adding a transition on a straight cut and doing nothing with that cut.
Turn on Show Through Edits under the wrench in the timeline.
Votes
Translate
Translate
Report
Report
Engaged ,
Mar 30, 2018 Mar 30, 2018
LATEST
Thanks for the great suggestion, Ann!
Votes
Translate
Translate
Report
Report
LEGEND ,
Ann's comment about turning on Show Through Edits ... is a real brain-saver on working with transitions. Highly recommended!
Neil
Votes
Translate
Translate
Report
Report
