1 Reply Latest reply on Mar 29, 2018 8:35 AM by Roland Kahlenberg
    Customizing keyboard layer selection shortcut (no 0 option listed)
    markh55163738
      Hi, I am currently customizing my shortcuts in After Effects because I do not have a numeral pad, I just have the standard row of numbers above my letters on my laptop. I am currently changing the layer selection shortcut (which is just typing the numeral attached to the layer), but realized there is no option for 0 which means I can't quickly jump to layer 10, 20, 30, ect. Does anyone know a workaround to this issue? Also, if there is an option to quickly change the keyboard type that you are using so that the shortcuts update quickly. For instance toggling to a keyboard layout that does not have the numeral pad so I don't have to replace each shortcut that says "1 (Num)" with "1".  Below is a screenshot of the issue I found in the shortcut customization window.
