Hi, All.
I hope you are doing well.
My plugin has some issue on adjustment layer when using PF_OutFlag_NON_PARAM_VARY for out flag.
Problem:
Only the first keyframe's value works when I apply keyframes to an adjustment layer.
How can I solve this problem?
Regards,
Anthonie.
err... what exatcly do you mean by "only the first keyframe's value works".
does you plug-in get a render cal for every frame, but AE fetches you the
wrong param values?
For example, I applied plugin to adjustment layer and set 2 keyframes. I've set rotation angle to 30 degree on the first keyframe and 120 degree on the second keyframe. Everytime render is called, the angle should increase from 30 to 120 but it maintains 30 degree always.
This issue appears only when I use this flag - PF_OutFlag_NON_PARAM_VARY.
Also if I don't use adjustment layer and apply plugin to the actual layer, this issue doesn't appear.
Regards,
Anthonie.
sooo... if you put a break point in your render function, you see AE is
sending the first rotation value on every frame?
i've never heared of such behavior. it seems more likely to me that AE is
caching the render result of the first frame and doesn't send any more
render calls.
i'm just trying to rule out the causes.
On Fri, Mar 30, 2018 at 11:57 AM, smarts19193560 <forums_noreply@adobe.com>
Thank you. shachar.
Sorry, I forgot a problem.
I converted the plugin to premiere pro and tested on that. So, above problem appears on premiere pro not AE.
ah... we'll, PP is not my field of expertise so i'm afraid i don't have any
insight for you on that one...
Thank you. shachar.
Then may I ask about that on PP forum?
Actually the flag (PF_OutFlag_NON_PARAM_VARY) is in AE_Effect.h.
So, I asked about that here.
Regards,
Anthonie.
you may ask wherever you feel is appropriate! this forum is not being
policed.
you can also try contacting zaclam directly. it might be a bug with PP.
Thanks for your help.
Can I contact zaclam directly to solve this problem? Or can he see this question?
Regards,
Anthonie.
he usually looks at this forum and responds when needed, but you can also
send him an email. (i think the address is in the SDK pdf)
On Fri, Mar 30, 2018 at 12:42 PM, smarts19193560 <forums_noreply@adobe.com>
Hi, Shachar.
Can I use another out flag not PF_OutFlag_NON_PARAM_VARY to call render function every time?
Regards,
Anthonie.
before you do that, know that PF_OutFlag_NON_PARAM_VARY should work...
in AE you can try using GuidMixInPtr(). i'm pretty sure that doesn't apply
to PP.
On Thu, Apr 5, 2018 at 4:31 PM, smarts19193560 <forums_noreply@adobe.com>
perhaps you can try creating a simplified plug-in to see if indeed PP is
ignoring PF_OutFlag_NON_PARAM_VARY.
if the simplified plug-in gets called you'll know it's something else in
your design that causes the issue...
Hi, Shachar.
I checked on a simple plugin - shifter. Without PF_OutFlag_NON_PARAM_VARY flag it works well with adjustment layer.
But when I add the flag to the plugin the error appears.
Regards,
Anthonie.
