6 Replies Latest reply on Jun 24, 2008 4:59 PM by FredenFromSweden
    Creating New Fields On The Fly
    FredenFromSweden Level 1
      Hey all - trying to set up button, or whatever, to allow the user to add and remove TextInputs on the fly. But, I just can't 'think' of how to do it. I'm thinking a changing variable name for each new field, or some sort of array or object but just can't nail it down.
      Any help?
      thanks,
      M
        • 1. Re: Creating New Fields On The Fly
          peterent2 Adobe Employee
          Let's say you have a simple <mx:Application> (main application file) and you want to add a TextInput field to it. In the function called from the Button's click event handler, do this:
          var newInput:TextInput = new TextInput();
          addChild(newInput);
          Depending on how the container (in this case it is the Application) layout is set you may need to set the newInput.x and inputInput.y properties, too.
          • 2. Re: Creating New Fields On The Fly
            Cool - thanks.
            I guess I forgot to mention that I would like it to be multiple fields. I've got the
            addChild(newInput);
            done - but if I want more fields I guess I need to make a new TextInput with a different var name... and that's where I'm having trouble.
            How would I go about making a var with a dynamic name, so I could have newInput1, newInput2, etc…
            Or, should I go about it a different way?
            thanks for the help!
            M
            • 3. Re: Creating New Fields On The Fly
              |>AoA<|_killa Level 1
              You could make an array of them(thats how I did it in C#) and there is probably a function somewhere to look up controls according to their id or so.
              • 4. Re: Creating New Fields On The Fly
                Make sure you declare your class to be dynamic, this will allow you to add new properties to it on the fly:
                public dynamic class MyComponent extends ...whatever...
                Then you can create new members of the class like this:
                var input:TextInput = new TextInput();
                addChild(input);
                this[ "id"+numChildren ] = input;
                You can also store them in an Array, as well. This is what we do inside of some components.
                --peter
                • 5. Re: Creating New Fields On The Fly
                  levancho Level 3
                  quote:
                  --peter
                  not a good idea at all, dynamic classes are performance overhead, and for this problem is not needed at all,
                  instead you have several options : you can either do :
                  for loop (var loopCounter:int ; comparison;loopCounter++) {
                  var ti:TextInput = new TextInput()
                  ti.name = "myName"+loopCounter;
                  this.addChild(ti);
                  then you can do : this.getChildByName("myName1") to get refference etc ....
                  option 2 :
                  private var storage:Object - new Object () ;
                  var ti:TextInput ;
                  ti = new TextInput()
                  storage[("lalala"+loopCounter)] = this.addChild(ti);
                  then you can get reference to needed inputBox by just doing
                  ti = (storage["lalala1"] as TextInput);
                  • 6. Re: Creating New Fields On The Fly
                    Nice - Nice. That's just what I needed levancho.
                    This is what I came up with. I'm a newbie to Flex/AS so lemme know if there's a better way to do it.
                    Thanks for everyones input!
