When I try to do this, I am unable.
In the CC Glass effect, under the "Light" toggle options, in the "Using" selection, there are two options: "Effect Light" and "AE Lights." When I try to set the effect to use "AE Lights," it says AE Lights (requires CCfx HD). This is referring to "CyCore Effects HD."
Thing is, After Effects CS5.5 DOES seem to have this.
So, unless I'm missing something, it seems that logically, After Effects should be recognizing it. But somehow, it isn't. CC Glass is either not recognizing it or registering it.
What do I need to do to fix this? If anyone knows what the solution to this is, I would greatly appreciate an answer as soon as possible.
Jeremy Schafer
The HD versions of the Cycore effects were only included in CS6 and upwards. Before you had to buy and license them separately. So what you attempt to do won't work unless you have a legacy license for CCfx HD.
Mylenium
Mylenium
Okay, thank you.
