When i go to Filter -->Render, tree, flame and lightning effects are grayed out and i don't know what to do. Please help me. Sorry for my bad English
Render Tree uses GPU acceleration
Photoshop graphics processor (GPU) card FAQ
Check out Preferences > Performance and see what your settings are. If you are not able to turn it on, make sure your video card driver is up to date, and from the card maker's site
[EDIT] I have just had a wee experiment and Render > Tree just needs GPU acceleration to be turned on. It doesn't need Drawing Mode set to Advanced, for instance. If you are not sure about your situation, open Photoshop and go Help > Syste
...Copy link to clipboard
[EDIT] I have just had a wee experiment and Render > Tree just needs GPU acceleration to be turned on. It doesn't need Drawing Mode set to Advanced, for instance. If you are not sure about your situation, open Photoshop and go Help > System Info > Copy and paste to this thread.
Adobe Photoshop Version: 2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006 x32
Number of Launches: 3
Version: 7 SP1
System architecture: Intel CPU Family:6, Model:7, Stepping:10 with MMX, SSE Integer, SSE FP, SSE2, SSE3
Physical processor count: 2
Processor speed: 2792 MHz
Built-in memory: 3647 MB
Free memory: 1331 MB
Memory available to Photoshop: 2510 MB
Memory used by Photoshop: 61 %
Alias Layers: ^0
Modifier Palette: Disabled.
3D Multitone Printing: Disabled.
Highbeam: Enabled.
Image tile size: 128K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=900, right=1600
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=1024
glgpu[0].GLName="NVIDIA GeForce GT 730"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="23.21.13.9135"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="GeForce GT 730/PCIe/SSE2"
glgpu[0].GLRendererID=4743
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="nvd3dum.dll,nvwgf2um.dll,nvwgf2um.dll"
glgpu[0].GLDriverDate="20180323000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.60 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2"
clgpu[0].CLDeviceVersion="1.2 CUDA"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=1024
clgpu[0].CLName="GeForce GT 730"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="391.35"
clgpu[0].CLBandwidth=0
clgpu[0].CLCompute=0
License Type: Perpetual
Serial number: 91198126390575465095
GUIDBucket:
bucket: 88
test: ReduceUXFriction
Application folder: D:\HUY\Photoshop18\App\Ps\
Temporary file path: C:\Users\PC\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 50.0G, 7.02G free
Required Plug-ins folder: D:\HUY\Photoshop18\App\Ps\Required\Plug-ins\
Primary Plug-ins folder: D:\HUY\Photoshop18\App\Ps\Plug-ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2016/09/17-17:22:04 79.577309 79.577309
AdbePM.dll PatchMatch 2016/05/17:03:10:18 1.573920 1.573920
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2016/08/10-16:53:20 79.195992 79.195992
AdobePIP.dll Adobe Product Improvement Program 7.4.1.60.45263
AdobeSVGAGM.dll AdobeSVGAGM 79.577309 79.577309
AdobeXMP.dll Adobe XMP Core 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPFiles.dll Adobe XMP Files 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPScript.dll Adobe XMP Script 2016/09/14-01:09:01 79.159824 79.159824
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2016/09/17-17:22:04 79.577309 79.577309
ahclient.dll AdobeHelp Dynamic Link Library 2.0.0.2
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTEmu 10.0.0.3BuildVersion: 10.0; BuildDate: Thu Apr 21 2016 3:6:38)
ARE.dll ARE 2016/09/17-17:22:04 79.577309 79.577309
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2016/09/17-17:22:04 79.577309 79.577309
BIBUtils.dll BIBUtils 2016/09/17-17:22:04 79.577309 79.577309
boost_date_time.dll photoshopdva 10.0.0
boost_signals.dll photoshopdva 10.0.0
boost_system.dll photoshopdva 10.0.0
boost_threads.dll photoshopdva 10.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CIT.dll Adobe CIT 2.1.0.1 2.1.0.1
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2016/09/17-17:22:04 79.577309 79.577309
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 10.0.0
dvacore.dll photoshopdva 10.0.0
dvamarshal.dll photoshopdva 10.0.0
dvamediatypes.dll photoshopdva 10.0.0
dvametadata.dll photoshopdva 10.0.0
dvametadataapi.dll photoshopdva 10.0.0
dvametadataui.dll photoshopdva 10.0.0
dvaplayer.dll photoshopdva 10.0.0
dvatransport.dll photoshopdva 10.0.0
dvaui.dll photoshopdva 10.0.0
dvaunittesting.dll photoshopdva 10.0.0
dynamiclink.dll photoshopdva 10.0.0
ExtendScript.dll ExtendScript 2016/01/26-16:09:33 80.1060872 80.1060872
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.1
JP2KLib.dll JP2KLib 2016/05/26-01:08:58 79.262945 79.262945
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
LogSession.dll LogSession 7.4.1.60.45263
mediacoreif.dll photoshopdva 10.0.0
MPS.dll MPS 2016/09/14-15:20:26 79.577269 79.577269
msvcp100.dll Microsoft® Visual Studio® 2010 10.00.40219.325
msvcp110.dll Microsoft® Visual Studio® 2012 11.00.51106.1
msvcp120.dll Microsoft® Visual Studio® 2013 12.00.21005.1
msvcr100.dll Microsoft® Visual Studio® 2010 10.00.40219.325
msvcr110.dll Microsoft® Visual Studio® 2012 11.00.51106.1
msvcr120.dll Microsoft® Visual Studio® 2013 12.00.21005.1
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2017 18.0.0
Plugin.dll Adobe Photoshop CC 2017 18.0.0
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (32 bit) 7.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (32 bit) 7.0.0.67
PSArt.dll Adobe Photoshop CC 2017 18.0.0
PSViews.dll Adobe Photoshop CC 2017 18.0.0
SCCore.dll ScCore 2016/01/26-16:09:33 80.1060872 80.1060872
SVGRE.dll SVGRE 79.577309 79.577309
svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
tbb.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WRServices.dll WRServices Thu Jan 07 2016 04:50:10 Build 0.21960 0.21960
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D.8bi”
Accented Edges 18.0.0 - from the file “Filter Gallery.8bf”
Adaptive Wide Angle 18.0.0 - from the file “Adaptive Wide Angle.8bf”
Angled Strokes 18.0.0 - from the file “Filter Gallery.8bf”
Average 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “Average.8bf”
Bas Relief 18.0.0 - from the file “Filter Gallery.8bf”
BMP 18.0.0 - from the file “Standard MultiPlugin.8bf”
Camera Raw 9.7 - from the file “Camera Raw.8bi”
Camera Raw Filter 9.7 - from the file “Camera Raw.8bi”
Chalk && Charcoal 18.0.0 - from the file “Filter Gallery.8bf”
Chrome 18.0.0 - from the file “Filter Gallery.8bf”
Cineon 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “Cineon.8bi”
Clouds 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “Clouds.8bf”
Collada 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D.8bi”
Color Halftone 18.0.0 - from the file “Standard MultiPlugin.8bf”
Colored Pencil 18.0.0 - from the file “Filter Gallery.8bf”
CompuServe GIF 18.0.0 - from the file “Standard MultiPlugin.8bf”
Conté Crayon 18.0.0 - from the file “Filter Gallery.8bf”
Craquelure 18.0.0 - from the file “Filter Gallery.8bf”
Crop and Straighten Photos 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “CropPhotosAuto.8li”
Crop and Straighten Photos Filter 18.0.0 - from the file “Standard MultiPlugin.8bf”
Crosshatch 18.0.0 - from the file “Filter Gallery.8bf”
Crystallize 18.0.0 - from the file “Standard MultiPlugin.8bf”
Cutout 18.0.0 - from the file “Filter Gallery.8bf”
Dark Strokes 18.0.0 - from the file “Filter Gallery.8bf”
De-Interlace 18.0.0 - from the file “Standard MultiPlugin.8bf”
Dicom 18.0.0 - from the file “Dicom.8bi”
Difference Clouds 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “Clouds.8bf”
Diffuse Glow 18.0.0 - from the file “Filter Gallery.8bf”
Displace 18.0.0 - from the file “Standard MultiPlugin.8bf”
Dry Brush 18.0.0 - from the file “Filter Gallery.8bf”
Eazel Acquire 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “EazelAcquire.8ba”
Entropy 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics.8ba”
Export Color Lookup Tables NO VERSION - from the file “Export3DLUT.8be”
Extrude 18.0.0 - from the file “Standard MultiPlugin.8bf”
FastCore Routines 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “FastCore.8bx”
Fibers 18.0.0 - from the file “Standard MultiPlugin.8bf”
Film Grain 18.0.0 - from the file “Filter Gallery.8bf”
Filter Gallery 18.0.0 - from the file “Filter Gallery.8bf”
Flash 3D 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D.8bi”
Fresco 18.0.0 - from the file “Filter Gallery.8bf”
Glass 18.0.0 - from the file “Filter Gallery.8bf”
Glowing Edges 18.0.0 - from the file “Filter Gallery.8bf”
Google Earth 4 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D.8bi”
Graphic Pen 18.0.0 - from the file “Filter Gallery.8bf”
Halftone Pattern 18.0.0 - from the file “Filter Gallery.8bf”
HDRMergeUI 18.0.0 - from the file “HDRMergeUI.8bf”
HSB/HSL 18.0.0 - from the file “Standard MultiPlugin.8bf”
IFF Format 18.0.0 - from the file “Standard MultiPlugin.8bf”
IGES 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D.8bi”
Ink Outlines 18.0.0 - from the file “Filter Gallery.8bf”
JPEG 2000 18.0.0 - from the file “JPEG2000.8bi”
Kurtosis 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics.8ba”
Lens Blur 18.0.0 - from the file “Lens Blur.8bf”
Lens Correction 18.0.0 - from the file “Lens Correction.8bf”
Lens Flare 18.0.0 - from the file “Standard MultiPlugin.8bf”
Liquify 18.0.0 - from the file “Liquify.8bf”
Matlab Operation 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “ChannelPort.8bf”
Maximum 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics.8ba”
Mean 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics.8ba”
Measurement Core 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “MeasurementCore.8me”
Median 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics.8ba”
Mezzotint 18.0.0 - from the file “Standard MultiPlugin.8bf”
Minimum 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics.8ba”
MMXCore Routines 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “MMXCore.8bx”
Mosaic Tiles 18.0.0 - from the file “Filter Gallery.8bf”
Multiprocessor Support 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “MultiProcessor Support.8bx”
Neon Glow 18.0.0 - from the file “Filter Gallery.8bf”
Note Paper 18.0.0 - from the file “Filter Gallery.8bf”
NTSC Colors 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “NTSC Colors.8bf”
Ocean Ripple 18.0.0 - from the file “Filter Gallery.8bf”
OpenEXR 18.0.0 - from the file “Standard MultiPlugin.8bf”
Paint Daubs 18.0.0 - from the file “Filter Gallery.8bf”
Palette Knife 18.0.0 - from the file “Filter Gallery.8bf”
Patchwork 18.0.0 - from the file “Filter Gallery.8bf”
Paths to Illustrator 18.0.0 - from the file “Standard MultiPlugin.8bf”
PCX 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “PCX.8bi”
Photocopy 18.0.0 - from the file “Filter Gallery.8bf”
Photoshop 3D Engine 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “Photoshop3DEngine.8bi”
Photoshop Touch 14.0 - from the file “PSDX.8bi”
Picture Package Filter 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “ChannelPort.8bf”
Pinch 18.0.0 - from the file “Standard MultiPlugin.8bf”
Pixar 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “Pixar.8bi”
Plaster 18.0.0 - from the file “Filter Gallery.8bf”
Plastic Wrap 18.0.0 - from the file “Filter Gallery.8bf”
PLY 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D.8bi”
PNG 18.0.0 - from the file “Standard MultiPlugin.8bf”
Pointillize 18.0.0 - from the file “Standard MultiPlugin.8bf”
Polar Coordinates 18.0.0 - from the file “Standard MultiPlugin.8bf”
Portable Bit Map 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “PBM.8bi”
Poster Edges 18.0.0 - from the file “Filter Gallery.8bf”
PRC 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D.8bi”
Radial Blur 18.0.0 - from the file “Standard MultiPlugin.8bf”
Radiance 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “Radiance.8bi”
Range 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics.8ba”
Render Color Lookup Grid NO VERSION - from the file “Export3DLUT.8be”
Reticulation 18.0.0 - from the file “Filter Gallery.8bf”
Ripple 18.0.0 - from the file “Standard MultiPlugin.8bf”
Rough Pastels 18.0.0 - from the file “Filter Gallery.8bf”
Save for Web 18.0.0 - from the file “Save for Web.8be”
ScriptingSupport 18.0.0 - from the file “ScriptingSupport.8li”
Shake Reduction 18.0.0 - from the file “Shake Reduction.8bf”
Shear 18.0.0 - from the file “Standard MultiPlugin.8bf”
Skewness 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics.8ba”
Smart Blur 18.0.0 - from the file “Standard MultiPlugin.8bf”
Smudge Stick 18.0.0 - from the file “Filter Gallery.8bf”
Solarize 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “Solarize.8bf”
Spatter 18.0.0 - from the file “Filter Gallery.8bf”
Spherize 18.0.0 - from the file “Standard MultiPlugin.8bf”
Sponge 18.0.0 - from the file “Filter Gallery.8bf”
Sprayed Strokes 18.0.0 - from the file “Filter Gallery.8bf”
Stained Glass 18.0.0 - from the file “Filter Gallery.8bf”
Stamp 18.0.0 - from the file “Filter Gallery.8bf”
Standard Deviation 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics.8ba”
STL 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D.8bi”
Sumi-e 18.0.0 - from the file “Filter Gallery.8bf”
Summation 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics.8ba”
Targa 18.0.0 - from the file “Standard MultiPlugin.8bf”
Texturizer 18.0.0 - from the file “Filter Gallery.8bf”
Tiles 18.0.0 - from the file “Standard MultiPlugin.8bf”
Torn Edges 18.0.0 - from the file “Filter Gallery.8bf”
Twirl 18.0.0 - from the file “Standard MultiPlugin.8bf”
U3D 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D.8bi”
Underpainting 18.0.0 - from the file “Filter Gallery.8bf”
Vanishing Point 18.0.0 - from the file “VanishingPoint.8bf”
Variance 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “statistics.8ba”
Virtual Reality Modeling Language | VRML 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D.8bi”
Water Paper 18.0.0 - from the file “Filter Gallery.8bf”
Watercolor 18.0.0 - from the file “Filter Gallery.8bf”
Wave 18.0.0 - from the file “Standard MultiPlugin.8bf”
Wavefront|OBJ 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “U3D.8bi”
WIA Support 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “WIASupport.8li”
Wind 18.0.0 - from the file “Standard MultiPlugin.8bf”
Wireless Bitmap 18.0.0 (2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006) - from the file “WBMP.8bi”
ZigZag 18.0.0 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.inapp.purchase 2.7.122 - from the file “D:\HUY\Photoshop18\App\Ps\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
New Document 2.0.1 - from the file “C:\Users\PC\AppData\Roaming\Adobe\CEP\extensions\CCX_CMDN_EXTENSION_2_0_1_001\fnft.html”
Libraries 2.7.122 - from the file “D:\HUY\Photoshop18\App\Ps\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
com.adobe.experimentation.extension 2.0.0 - from the file “D:\HUY\Photoshop18\App\Ps\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
Start 2.0.1 - from the file “C:\Users\PC\AppData\Roaming\Adobe\CEP\extensions\CCX_START_EXTENSION_2_0_1_044\index.html”
Adobe Color Themes 6.1.0 - from the file “D:\HUY\Photoshop18\App\Ps\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Export As 3.0.8 - from the file “D:\HUY\Photoshop18\App\Ps\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Device Preview 1.3.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
com.adobe.preview.loader 1.3.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
Installed TWAIN devices: NONE
That looks OK. Is it working now? I haven't looked through your system info yet.
Your spec is a wee bit marginal.
Only 2 cores, but a reasonable clock speed.
Memory is on the low side, but it's enough for Photoshop to operate.
You do have a unique GPU which is good news, as it will have its own memory
And the driver is right up to date. It looks like you are good to go. Is it working now?
no, it isn't. Please help me !!!
Number of Launches: 238
Version: 8.1
System architecture: Intel CPU Family:6, Model:10, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
Logical processor count: 4
Processor speed: 2494 MHz
Built-in memory: 3983 MB
Free memory: 2279 MB
Memory available to Photoshop: 3255 MB
Memory used by Photoshop: 70 %
Alias Layers: ^0
Modifier Palette: Enabled.
Highbeam: Disabled.
Image cache levels: 5
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=768, right=1366
OpenGL Drawing: Disabled.
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.0"
glgpu[0].GLMemoryMB=1799
glgpu[0].GLName="Intel(R) HD Graphics 4000"
glgpu[0].GLVendor="Intel"
glgpu[0].GLVendorID=32902
glgpu[0].GLDriverVersion="9.17.10.2849"
glgpu[0].GLRectTextureSize=8192
glgpu[0].GLRenderer="Intel(R) HD Graphics 4000"
glgpu[0].GLRendererID=358
glgpu[0].GLDriver="igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32"
glgpu[0].GLDriverDate="20120902000000.000000-000"
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 9.17.10.2849"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[80]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[1024]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[1024]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
GUIDBucket:
bucket: 88
Application folder: C:\Program Files (x86)\Adobe\Adobe Photoshop CC 2017 (32 Bit)\
Temporary file path: C:\Users\SAMSUN~1\AppData\Local\Temp\
Scratch volume(s):
Startup, 200.8G, 9.40G free
Required Plug-ins folder: C:\Program Files (x86)\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\Plug-ins\
Primary Plug-ins folder: C:\Program Files (x86)\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Plug-ins\
Required plug-ins:
Extensions:
com.adobe.inapp.purchase 2.7.122 - from the file “C:\Program Files (x86)\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
Recent Files 1.4.0 - from the file “C:\Program Files (x86)\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\CEP\extensions\com.adobe.ccx.start\index.html”
Libraries 2.7.122 - from the file “C:\Program Files (x86)\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
New Document 1.4.0 - from the file “C:\Program Files (x86)\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\CEP\extensions\com.adobe.ccx.start\fnft.html”
com.adobe.experimentation.extension 2.0.0 - from the file “C:\Program Files (x86)\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
Start 1.4.0 - from the file “C:\Program Files (x86)\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\CEP\extensions\com.adobe.ccx.start\index.html”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files (x86)\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Export As 3.0.8 - from the file “C:\Program Files (x86)\Adobe\Adobe Photoshop CC 2017 (32 Bit)\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Could you please check mine? I also have the same problem and couldn't fix it ;'( Thanks before
Adobe Photoshop Version: 21.0.0 20191018.r.37 2019/10/18: 614690fb487 x64
Number of Launches: 28
Operating System: Windows 10 64-bit
Version: 10 or greater 10.0.18362.1110
System architecture: Intel CPU Family:6, Model:14, Stepping:12 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 2112 MHz
Built-in memory: 7909 MB
Free memory: 5054 MB
Memory available to Photoshop: 7220 MB
ACP.local Status:
- SDK Version: 1.22.4
- Core Sync Status: Reachable and compatible
- Core Sync Running: 4.3.60.8
- Min Core Sync Required: 4.3.4.2
ACPL Cache Config:
Alias Layers: Disabled.
Highbeam: Disabled.
Image tile size: 1024K
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=2
NumNativeGPUs=0
glgpu[0].GLName="Intel(R) UHD Graphics"
glgpu[0].GLDriverVersion="26.20.100.6911"
glgpu[0].GLRenderer="Intel(R) UHD Graphics"
glgpu[0].GLRendererID=39745
glgpu[0].GLDriver="C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_ea63d1eddd5853b5\igdumdim64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_ea63d1eddd5853b5\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_ea63d1eddd5853b5\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_ea63d1eddd5853b5\igd12umd64.dll"
glgpu[0].GLDriverDate="20190528000000.000000-000"
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 26.20.100.6911"
clgpu[0].CLPlatformVersion="2.1 "
clgpu[0].CLDeviceVersion="2.1 NEO "
clgpu[0].IsIntegratedCLGPU=1
clgpu[0].CLMemoryMB=3163
clgpu[0].CLName="Intel(R) UHD Graphics"
clgpu[0].CLVendor="Intel(R) Corporation"
clgpu[0].CLVendorID=32902
clgpu[0].CLDriverVersion="26.20.100.6911"
clgpu[0].CLBandwidth=1.96135e+10
clgpu[0].CLCompute=184.959
clgpu[1].CLPlatformVersion="1.2"
clgpu[1].CLDeviceVersion="1.2 CUDA"
clgpu[1].IsIntegratedCLGPU=0
clgpu[1].CLMemoryMB=2048
clgpu[1].CLName="GeForce MX230"
clgpu[1].CLVendor="NVIDIA Corporation"
clgpu[1].CLVendorID=4318
clgpu[1].CLDriverVersion="430.90"
clgpu[1].CLBandwidth=3.40128e+10
clgpu[1].CLCompute=351.978
License Type: Unknown
Serial number:
GUIDBucket:Composite Core (enable_composite_core): onComposite Core GPU (comp_core_gpu): offComposite Core UI (comp_core_ui): offDocument Graph (enable_doc_graph): off
Application folder: C:\Program Files\Adobe\Adobe Photoshop 2020\
Temporary file path: C:\Users\Syakir\AppData\Local\Temp\
Scratch volume(s):
Startup, 475.8G, 310.6G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop 2020\Required\Plug-ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop 2020\Plug-ins\
ACE.dll ACE 2019/09/17-01:11:26 79.613319 79.613319
AdbePM.dll PatchMatch 2019/09/25:16:59:41 1.613549 1.613549
AdobeLinguistic.dll Adobe Linguisitc Library 14.0.0.0
AdobeOwl.dll Adobe Owl 5.5.0
AdobePDFL.dll PDFL 2019/09/09-16:07:36 79.348578 79.348578
AdobePIP.dll Adobe Product Improvement Program 8.1.0.40.48685
AdobeSVGAGM.dll AdobeSVGAGM 79.613055 79.613055
AdobeXMP.dll Adobe XMP Core 2019/08/13-01:06:57 79.164036 79.164036
AdobeXMPFiles.dll Adobe XMP Files 2019/08/13-01:06:57 79.164036 79.164036
AdobeXMPScript.dll Adobe XMP Script 2019/08/13-01:06:57 79.164036 79.164036
AGM.dll AGM 2019/09/17-01:11:26 79.613319 79.613319
ahclient.dll AdobeHelp Dynamic Link Library 4.0.0.0
AIDE.dll AIDE 2019/09/09-16:07:36 79.613133 79.613133
ARE.dll ARE 2019/09/17-01:11:26 79.613319 79.613319
AXE8SharedExpat.dll AXE8SharedExpat 2019/09/16-11:49:24 79.613314 79.613314
AXEDOMCore.dll AXEDOMCore 2019/09/16-11:49:24 79.613314 79.613314
Bib.dll BIB 2019/09/17-01:11:26 79.613319 79.613319
BIBUtils.dll BIBUtils 2019/09/17-01:11:26 79.613319 79.613319
boost_date_time.dll photoshopdva 12.1.0
boost_filesystem.dll photoshopdva 12.1.0
boost_system.dll photoshopdva 12.1.0
boost_threads.dll photoshopdva 12.1.0
CoolType.dll CoolType 2019/09/17-01:11:26 79.613319 79.613319
CRClient.dll Adobe Crash Reporter Client DLL 2.0.3.0
dvaaccelerate.dll photoshopdva 12.1.0
dvaappsupport.dll photoshopdva 12.1.0
dvaaudiodevice.dll photoshopdva 12.1.0
dvacore.dll photoshopdva 12.1.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 12.1.0
dvamediatypes.dll photoshopdva 12.1.0
dvametadata.dll photoshopdva 12.1.0
dvametadataapi.dll photoshopdva 12.1.0
dvametadataui.dll photoshopdva 12.1.0
dvaplayer.dll photoshopdva 12.1.0
dvascripting.dll photoshopdva 12.1.0
dvatransport.dll photoshopdva 12.1.0
dvaui.dll photoshopdva 12.1.0
dvaunittesting.dll photoshopdva 12.1.0
dynamiclink.dll photoshopdva 12.1.0
ExtendScript.dll ExtendScript 2019/07/29-10:07:31 82.2 82.2
icucnv64.dll International Components for Unicode Build gtlib_12.0.24171
icudt64.dll International Components for Unicode Build gtlib_12.0.24171
icuuc64.dll International Components for Unicode Build gtlib_12.0.24171
JP2KLib.dll JP2KLib 2019/09/05-01:10:23 79.273548 79.273548
libmmd.dll Intel(R) C/C++/Fortran Compiler 19.0.0
LogSession.dll LogSession 8.1.0.40.48685
mediacoreif.dll photoshopdva 12.1.0
MPS.dll MPS 2019/09/27-13:40:09 79.613613 79.613613
pdfsettings.dll Adobe PDFSettings 1.07
Photoshop.dll Adobe Photoshop 2020 21.0
Plugin.dll Adobe Photoshop 2020 21.0
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 9.4.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 9.4.0.46
PSCloud.dll 1.0.0.1
PSViews.dll Adobe Photoshop 2020 21.0
SCCore.dll ScCore 2019/07/29-10:07:31 82.2 82.2
SVGRE.dll SVGRE 79.613055 79.613055
svml_dispmd.dll Intel(R) C/C++/Fortran Compiler 19.0.0
tbb.dll Intel(R) Threading Building Blocks for Windows 2019, 0, 2019, 0410
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 2019, 0, 2019, 0410
VulcanControl.dll Vulcan Application Control Library 5.6.1.39
VulcanMessage5.dll Vulcan Message Library 5.6.1.39
WinRTSupport.dll Adobe Photoshop Windows RT Support 21.0.0.0
WRServices.dll WRServices Build 15.2.0.24467 15.2.0.24467
Unified Extensibility Platform uxp-3.3.7.54
Required plug-ins:
Accented Edges 21.0 - from the file “Filter Gallery.8bf”
Adaptive Wide Angle 21.0 - from the file “Adaptive Wide Angle.8bf”
Angled Strokes 21.0 - from the file “Filter Gallery.8bf”
Average 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “Average.8bf”
Bas Relief 21.0 - from the file “Filter Gallery.8bf”
BMP 21.0 - from the file “Standard MultiPlugin.8bf”
Chalk && Charcoal 21.0 - from the file “Filter Gallery.8bf”
Chrome 21.0 - from the file “Filter Gallery.8bf”
Cineon 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “Cineon.8bi”
Clouds 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “Clouds.8bf”
Color Halftone 21.0 - from the file “Standard MultiPlugin.8bf”
Colored Pencil 21.0 - from the file “Filter Gallery.8bf”
Conté Crayon 21.0 - from the file “Filter Gallery.8bf”
Craquelure 21.0 - from the file “Filter Gallery.8bf”
Crop and Straighten Photos 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “CropPhotosAuto.8li”
Crop and Straighten Photos Filter 21.0 - from the file “Standard MultiPlugin.8bf”
Crosshatch 21.0 - from the file “Filter Gallery.8bf”
Crystallize 21.0 - from the file “Standard MultiPlugin.8bf”
Cutout 21.0 - from the file “Filter Gallery.8bf”
Dark Strokes 21.0 - from the file “Filter Gallery.8bf”
De-Interlace 21.0 - from the file “Standard MultiPlugin.8bf”
Dicom 21.0 - from the file “Dicom.8bi”
Difference Clouds 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “Clouds.8bf”
Diffuse Glow 21.0 - from the file “Filter Gallery.8bf”
Displace 21.0 - from the file “Standard MultiPlugin.8bf”
Dry Brush 21.0 - from the file “Filter Gallery.8bf”
Eazel Acquire 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “EazelAcquire.8ba”
Entropy 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “statistics.8ba”
Export Color Lookup Tables 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “Export3DLUT.8be”
Extrude 21.0 - from the file “Standard MultiPlugin.8bf”
FastCore Routines 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “FastCore.8bx”
Fibers 21.0 - from the file “Standard MultiPlugin.8bf”
Film Grain 21.0 - from the file “Filter Gallery.8bf”
Filter Gallery 21.0 - from the file “Filter Gallery.8bf”
Fresco 21.0 - from the file “Filter Gallery.8bf”
Glass 21.0 - from the file “Filter Gallery.8bf”
Glowing Edges 21.0 - from the file “Filter Gallery.8bf”
Graphic Pen 21.0 - from the file “Filter Gallery.8bf”
Halftone Pattern 21.0 - from the file “Filter Gallery.8bf”
Halide Bottlenecks 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “HalideBottlenecks.8bx”
HDRMergeUI 21.0 - from the file “HDRMergeUI.8bf”
HSB/HSL 21.0 - from the file “Standard MultiPlugin.8bf”
IFF Format 21.0 - from the file “Standard MultiPlugin.8bf”
IGES 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “U3D.8bi”
Ink Outlines 21.0 - from the file “Filter Gallery.8bf”
JPEG 2000 21.0 - from the file “JPEG2000.8bi”
Kurtosis 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “statistics.8ba”
Lens Blur 21.0 - from the file “Lens Blur.8bf”
Lens Correction 21.0 - from the file “Lens Correction.8bf”
Lens Flare 21.0 - from the file “Standard MultiPlugin.8bf”
Liquify 21.0 - from the file “Liquify.8bf”
Matlab Operation 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “ChannelPort.8bf”
Maximum 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “statistics.8ba”
Mean 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “statistics.8ba”
Measurement Core 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “MeasurementCore.8me”
Median 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “statistics.8ba”
Mezzotint 21.0 - from the file “Standard MultiPlugin.8bf”
Minimum 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “statistics.8ba”
MMXCore Routines 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “MMXCore.8bx”
Mosaic Tiles 21.0 - from the file “Filter Gallery.8bf”
Multiprocessor Support 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “MultiProcessor Support.8bx”
Neon Glow 21.0 - from the file “Filter Gallery.8bf”
Note Paper 21.0 - from the file “Filter Gallery.8bf”
NTSC Colors 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “NTSC Colors.8bf”
Ocean Ripple 21.0 - from the file “Filter Gallery.8bf”
OpenEXR 21.0 - from the file “Standard MultiPlugin.8bf”
Paint Daubs 21.0 - from the file “Filter Gallery.8bf”
Palette Knife 21.0 - from the file “Filter Gallery.8bf”
Patchwork 21.0 - from the file “Filter Gallery.8bf”
Paths to Illustrator 21.0 - from the file “Standard MultiPlugin.8bf”
PCX 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “PCX.8bi”
Photocopy 21.0 - from the file “Filter Gallery.8bf”
Picture Package Filter 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “ChannelPort.8bf”
Pinch 21.0 - from the file “Standard MultiPlugin.8bf”
Pixar 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “Pixar.8bi”
Plaster 21.0 - from the file “Filter Gallery.8bf”
Plastic Wrap 21.0 - from the file “Filter Gallery.8bf”
Pointillize 21.0 - from the file “Standard MultiPlugin.8bf”
Polar Coordinates 21.0 - from the file “Standard MultiPlugin.8bf”
Portable Bit Map 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “PBM.8bi”
Poster Edges 21.0 - from the file “Filter Gallery.8bf”
PRC 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “U3D.8bi”
Radial Blur 21.0 - from the file “Standard MultiPlugin.8bf”
Radiance 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “Radiance.8bi”
Range 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “statistics.8ba”
Render Color Lookup Grid 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “Export3DLUT.8be”
Reticulation 21.0 - from the file “Filter Gallery.8bf”
Ripple 21.0 - from the file “Standard MultiPlugin.8bf”
Rough Pastels 21.0 - from the file “Filter Gallery.8bf”
Save for Web 21.0 - from the file “Save for Web.8be”
ScriptingSupport 21.0 - from the file “ScriptingSupport.8li”
Shake Reduction 21.0 - from the file “Shake Reduction.8bf”
Shear 21.0 - from the file “Standard MultiPlugin.8bf”
Skewness 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “statistics.8ba”
Smart Blur 21.0 - from the file “Standard MultiPlugin.8bf”
Smudge Stick 21.0 - from the file “Filter Gallery.8bf”
Solarize 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “Solarize.8bf”
Spaces 21.0 - from the file “Spaces.8li”
Spatter 21.0 - from the file “Filter Gallery.8bf”
Spherize 21.0 - from the file “Standard MultiPlugin.8bf”
Sponge 21.0 - from the file “Filter Gallery.8bf”
Sprayed Strokes 21.0 - from the file “Filter Gallery.8bf”
Stained Glass 21.0 - from the file “Filter Gallery.8bf”
Stamp 21.0 - from the file “Filter Gallery.8bf”
Standard Deviation 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “statistics.8ba”
Sumi-e 21.0 - from the file “Filter Gallery.8bf”
Summation 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “statistics.8ba”
Targa 21.0 - from the file “Standard MultiPlugin.8bf”
Texturizer 21.0 - from the file “Filter Gallery.8bf”
Tiles 21.0 - from the file “Standard MultiPlugin.8bf”
Torn Edges 21.0 - from the file “Filter Gallery.8bf”
Twirl 21.0 - from the file “Standard MultiPlugin.8bf”
U3D 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “U3D.8bi”
Underpainting 21.0 - from the file “Filter Gallery.8bf”
Vanishing Point 21.0 - from the file “VanishingPoint.8bf”
Variance 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “statistics.8ba”
Water Paper 21.0 - from the file “Filter Gallery.8bf”
Watercolor 21.0 - from the file “Filter Gallery.8bf”
Wave 21.0 - from the file “Standard MultiPlugin.8bf”
WIA Support 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “WIASupport.8li”
Wind 21.0 - from the file “Standard MultiPlugin.8bf”
Wireless Bitmap 21.0 (20191018.r.37 2019/10/18: 614690fb487) - from the file “WBMP.8bi”
ZigZag 21.0 - from the file “Standard MultiPlugin.8bf”
Unified Extensibility Platform - Extensions:
com.adobe.ccx.start 3.1.0.156 - from the file "C:\Program Files\Common Files\Adobe/UXP/Extensions\com.adobe.ccx.start-3.1.0\"
CDO: 1.62.2
CmdN: 1.0.0
CDP: 1.89.2
Extensions:
com.adobe.Butler.backend 2.3.4 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2020\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
Libraries 1.0.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_9_275\index.html”
com.adobe.stock.panel.licensing 0.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2020\Required\CEP\extensions\com.adobe.stock.panel.licensing\index.html”
New Document 3.4.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.fnft-3.4.0\fnft.html?v=3.4.0.16”
com.adobe.inapp.typekit.purchase 1.0.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_9_275\purchaseTypekit.html”
Home 2.14.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.start-2.14.0\index.html?v=2.14.0.22”
com.adobe.capture.extension 1.0.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_9_275\extensions\capture\capture.html”
com.adobe.stock.panel.licensing-embedded 1.0.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_9_275\extensions\stock-panel-licensing\index.html”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2020\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Export As 4.8.12 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2020\Required\CEP\extensions\com.adobe.photoshop.crema\index.html”
hi, good night I got it from the adobe website, downloaded the plugin, and unzipped it from the photoshop folder....it worked..https://helpx.adobe.com/br/photoshop/kb/optional-file-format- plugins.html, this is the step by step...
.hi, good night I got it from the adobe website, downloaded the plugin, and unzipped it from th
