1. Re: Brush moves the Canvas - Surface Pen
Ged Traynor Apr 2, 2018 7:01 AM (in response to sno_on)3 people found this helpfulHi
Try uninstalling this Windows update
You can also pause Windows updates for up to 35 days to prevent it been re-installed by going into advanced options and turning on Pause Updates
Also take a look at this thread
2. Re: Brush moves the Canvas - Surface Pen
sno_on Apr 2, 2018 9:14 AM (in response to sno_on)Thats it !! thanks for this super fast reply!
3. Re: Brush moves the Canvas - Surface Pen
LazyNezumi Apr 11, 2018 12:01 PM (in response to sno_on)3 people found this helpfulMicrosoft introduced new Windows Ink Pen behavior in a recent Win10 update. This causes your pen to pan the canvas in Photoshop. For more info, and instructions to revert to the old behavior, see this post:
https://www.reddit.com/r/Windowsink/comments/8508fi/controlling_pen_behavior_in_windows_10 /
4. Re: Brush moves the Canvas - Surface Pen
davescm Apr 11, 2018 2:41 PM (in response to LazyNezumi)Thanks LazyNezumi . I'd already switched to the Wintab use this morning. It does make you wonder what Microsoft are playing at making a change like that in teh background without a simple interface switch.
Dave
5. Re: Brush moves the Canvas - Surface Pen
LazyNezumi Apr 11, 2018 2:44 PM (in response to davescm)They have a history of introducing awful default-on features, so at least they're staying consistent!
6. Re: Brush moves the Canvas - Surface Pen
ca40864825 Apr 12, 2018 3:11 AM (in response to sno_on)if you have problems with your pen (my pen drags my workingfield to all directions when i use the brush or pencil) go to setup wacom tablet and go to calibrate (your pensil) and deselect Windows-inkt (left under) it could be that after the next update it wil be selected again, so deselect again if you have some troubles again. good luck.
7. Re: Brush moves the Canvas - Surface Pen
madgelly Apr 13, 2018 3:24 AM (in response to sno_on)hey there, can u tell me how can i remove the update? I have the remove option for security update but there's no remove button for system update!
8. Re: Brush moves the Canvas - Surface Pen
Ged Traynor Apr 13, 2018 3:34 AM (in response to madgelly)5 people found this helpfulNo need to remove the update you have two choices you can either
Do the following:
1. Use notepad to create a text file and type in :
UseSystemStylus 0
2. Save the file as PSUserConfig.txt in the following location
C: > Users > Username > AppData > Roaming > Adobe > Adobe Photoshop CC 2018 > Adobe Photoshop CC 2018 Settings3. Go to the Wacom tablet properties and for Photoshop under Mapping uncheck "Use Windows Ink"
Or
Run this command on an elevated Command Prompt
reg add HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Pen /v LegacyPenInteractionModel /t REG_DWORD /d 1 /f
9. Re: Brush moves the Canvas - Surface Pen
madgelly Apr 13, 2018 6:37 AM (in response to Ged Traynor)thank u so much. it fixed
10. Re: Brush moves the Canvas - Surface Pen
Ged Traynor Apr 13, 2018 6:40 AM (in response to madgelly)You're welcome
11. Re: Brush moves the Canvas - Surface Pen
shubhangim70975717 Apr 14, 2018 1:27 AM (in response to Ged Traynor)It really worked like a charm! I was frustrated for two days as I was not able to complete my work! Now I can! :')
12. Re: Brush moves the Canvas - Surface Pen
greeneyedcopper Apr 14, 2018 1:35 PM (in response to Ged Traynor)Thank you so much! This worked perfectly! I had to log out of CC and log back in for it to take effect but it's working like normal again! My workflow was suffering and I was becoming extremely frustrated so I wanted to be sure to respond and say thanks to you for your help!
13. Re: Brush moves the Canvas - Surface Pen
Ineedafingscreenname Apr 16, 2018 2:28 PM (in response to Ged Traynor)Thanks so much! I was having the same issue and this was a lifesaver!
14. Re: Brush moves the Canvas - Surface Pen
heatherm4028977 Apr 17, 2018 7:36 AM (in response to Ged Traynor)Seriously thank you so much.
15. Re: Brush moves the Canvas - Surface Pen
boaze57986627 Apr 17, 2018 9:13 AM (in response to Ged Traynor)thanks man! thats great!
16. Re: Brush moves the Canvas - Surface Pen
thiagovianna35 Apr 17, 2018 10:10 AM (in response to Ged Traynor)Thanks a lot... I was already going nuts!
17. Re: Brush moves the Canvas - Surface Pen
denzw Apr 17, 2018 10:26 AM (in response to madgelly)I found a reddit post from someone in the microsoft community apparently, and they said if you run this as an admin in the cmd box, it will fix everything without needing to uninstall anything. I did and it worked for me.
"reg add HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Pen /v LegacyPenInteractionModel /t REG_DWORD /d 1 /f"
of course, without the quotations.
18. Re: Brush moves the Canvas - Surface Pen
maryannee31174169 Apr 26, 2018 12:48 PM (in response to sno_on)I was having the same issues while using my Huion Tablet Monitor, I wasn't able to fix the problem following the suggestions above, but I did discover the initial problem Is indeed with the update, it did not install properly and Microsoft has an update to fix it. Here is a screenshot of what is says on Microsoft's website:
and here is the link to the site:
https://support.microsoft.com/en-us/help/4093105/windows-10-update-kb4093105
I downloaded this update and installed it, and now everything is working fine and I'm able to use my pen again.
Hope this Helps
