10 Replies Latest reply on Apr 3, 2018 9:23 AM by Zmajcet
    Photoshop gradient (don't work?) bug?
    Zmajcet
      I have not experienced something like that it could be  happen.in photoshop.
      I understand that programs can have errors,but something like that should not happen   Photoshop in this
      version(may be in other above CC 2014 ).
        ver : 2017 , 2018 , ver 19, and the version   19.1.2  - the latest update.
      What is the problem (try to doing-just few steps) see the problem  if create one layer (dimension document not important and nothing
      about it   because the problem is always the same)  and another layer and on the one is one gradient (fill metal)
      and on another is other gradient fill(not important which) , and when you turn (switch one layer between other it doing)
      but when it is turned   both  on no difference is appearing(no mixing one between other) what is no normally in CC 2014 and
      earlier version(i think not tried in cs6 yet because i was too much frustrared about itl).
      Am i dummy with using a 2017, 2018 or what is wrong in this (version) i don't know because nothing is
      logic vs  previous version where one layer (of two) influence  to other but in this version nothing changed if it was visible (both)  or not (the
      result,effect is the same) you need to try this to trust me or  yourself what you will see. And only what you can see difference (changing)is if you have turned on one layer(one) or other (two).
      i hope  i accurately  presented the problem and that you will take a time and try this on your computer and  response to me.
      thx.  Regards from Slovenia
        • 1. Re: Photoshop gradient (don't work?) bug?
          c.pfaffenbichler Level 8
          I don’t follow, please post screenshots with the pertinent Panels (Layers, Options, …) visible.
          What are the Layers’ Blend Modes?
          • 2. Re: Photoshop gradient (don't work?) bug?
            Zmajcet Level 1
            Please read this one more because i made mistake(grammar i repair and give it in upper CASE) on important information about the problem
            happen   Photoshop in this version(may be in other BELOW CC 2014 such as cs6).
            one layer (dimension document not important and nothing  about it   because the problem is always the same)  and another layer and on the one is one gradient (fill metal)  and on another is other gradient fill(not important which) , and when you turn (switch one layer between other it doing)  but when it is turned   both  on no difference is appearing(no mixing one  between other) what is  NOrMALLY in CC 2014 and
            logic vs  previous version where one layer (of two) influence  to other but in this version nothing changed if it was visible (both)  or not (the result,effect is the same) you need to try this to trust me or  yourself what
            i hope  i accurately  presented the problem and that you will take a time and try this on your computer and  response to me .  Regards from Slovenia
            • 3. Re: Photoshop gradient (don't work?) bug?
              Zmajcet Level 1
              no it is  much simplier  (without blending modes  ) i have  2 layers (rgb, cmyk not important  document also 8 or 16)  and on the one is one gradient(that i choose from ... you know where), and on the other is another gradient.
              And when you have turned the second layer nothing was change.
              and this bug?  was present only in mentioned version.
              Try this  and i hope that you  will find out the same.
              • 4. Re: Photoshop gradient (don't work?) bug?
                Zmajcet Level 1
                • 5. Re: Photoshop gradient (don't work?) bug?
                  Once again: Please post screenshots with the pertinent Panels visible.
                  • 6. Re: Photoshop gradient (don't work?) bug?
                    melissapiccone Adobe Community Professional
                    You have not described the problem clearly. Please post screenshots including your layers - your whole screen.
                    • 7. Re: Photoshop gradient (don't work?) bug?
                      Zmajcet Level 1
                      ok thx for answer also  to you i will attach screenshot in a few hour  but however ...
                      may be this can understand  anyone and can try it in 1 minute.
                      -make 2 layers(ver 2017-2018 19.1.2 update)
                      -on the each of layer make gradient
                      -turn visible of one layer and another (when it is only one visible it shows normally that layer who is visible)
                      -turn both and ''Bug '' problem  appears  nothing changed if are both turned (visible on) in the ver 2014
                      it doing normally that one layer (it is visible) effects to other but in tihs version nothing change to see.
                      • 8. Re: Photoshop gradient (don't work?) bug?
                        edited
                        Please stop wasting your time and just post the screenshots.
                        FAQ: How do I capture and post a screen shot or video?
                        • 9. Re: Photoshop gradient (don't work?) bug?
                          Warunicorn Adobe Community Professional
                          Are these gradient fill layers, not just layers with gradients applied to them? I'm guessing the former but I cannot make them bug out.
                          • 10. Re: Photoshop gradient (don't work?) bug?
                            Zmajcet Level 1
                            sorry for all my question and discussion .
                            The main culprit was me   when i use gradient on layer
                            in one version of Photoshop vs  other vsrsion of Photoshop
                              where i   claimed that doesn't work or what work in another version.
                            The problem is because i use in one version of photoshop
                            gradient opacity set to 100 and in another less than 100
                            and in this case i can see that one layer effecting to another .
                            That is all .
