One of my MOST USED preset is one created by the late great Rob Cole to clear the top of the history panel. In "lrtemplate" format it was very simple to create by creating a preset with ONE item selected and replacing that item with NoEdit=true.
As expected, this hand edited preset didn't convert to XMP.
s = {
id = "C135F085-12DB-4ED4-8418-8AD5B761B5BD",
internalName = "Clear Top",
title = "Clear Top",
type = "Develop",
value = {
settings = {
NoEdit = true,
uuid = "97315B7D-8C75-4D83-8985-6EC3876683D2",
version = 0,
I have tried to edit a new XMP preset to do the same with no success. Do any of you Lightroom programming gurus have any idea how to do this or is there a new SDK that documents the XMP preset format.
There is a link to the SDK if you wish to try creating your own artistic profiles. It may give an insight into how you may edit your existing profile. Click below to start downloading the zip file.
http://www.adobe.com/go/profile-sdk
Matt Kloskowski has some ready-made profiles/LUTs including a few free samples. Simply download, unzip and drag the folder into Camera Raw >> Settings
Thanks 99jon but I was referring to a DEVELOP preset. All the "Clear Top" preset does is allow you to select a point in the History panel and the preset will place a Clear Top preset in History that clears everything ABOVE the selected history step without changing ANYTHING. The above preset was created in earlier versions of Lightroom by unchecking everything except for Dehaze and then hand editing the Dehaze line to be NoEdit=true. I tried hand editing an XMP preset to get rid of Dehaze in a similar manner but was unsuccessful as Lightroom apparently checks all the presets every time it loads and removes ones that are not compatible (good idea BTW). I was just wondering if there is a similar coding command for XMP like NoEdit=true in the"lrtemplate" presets. The late-great Rob Cole created this preset idea a long time ago and I and several of my Lr friends use it all the time. Very handy.
So Bob what you are looking for is some way to Clear the History section list above a entry that you pick rendomly without actually removing edits those entries did to the image?
What happens when you place that original preset in a folder now being used by the newer version of LR? Does it show up?
Original .lrtemplate presets are not compatible with 7.3 and won't show up when placed in the new location. If they were compatible, Lightroom would not have to convert your existing presets In the first place.
JSM
What the Rob Cole's preset did was actually REMOVE the edit history AND edits above the history step that was chosen. This was useful when I wanted to get rid of recent edits and also not clutter up the history panel. This is similar to going back in history and selecting a step and doing an adjustment such as Dehaze. The Dehaze step is placed in history and the steps above are removed from the history panel AND the edits above are also removed. The Clear Top preset just placed a NoEdit command apparently. If I place the old preset in the folder it is removed when Lightroom starts as the command NoEdit is not compatible and can not be converted. If the XMP format had a similar command to NoEdit I could just do that. Considering I NEVER use Grain, for now I just created a preset to set GRAIN Amount to ZERO and manually removed the Size and Roughness from the XMP preset and it works fine. It would be nice to duplicate what I had. I have found no documentation on the XMP preset stuff.
Have you tried something like:
crs:HasSettings="False">
Would that achive what you want
That was a great idea but it did not work. It seems you have to have at least ONE setting to have the preset import without error. The HasSettings="False" does not get rid of this required settings. The lrtemplate had the NoEdit "setting" which got rid of the problem and maybe someone know about a similar "setting" for the XMP. Its not a deal breaker but was a handy tool several of us used and got used too. I know a couple of my Lr friends do not use GRAIN so the 0 grain workaround is ok but the programmer in me wants to get it to work.
99jon
You may have started me in the right direction. I have been doing a little more testing
If I set Grain="" instead of Grain="0" AND HasSettings to false than it seems to work. Doing it this way DOES NOT set Grain Amount slider to 0.
I will have to do a little more testing.
After more testing I still haven’t got this to work. The methods I thought were working had other issues.
And have you followed this
How to Install Presets in Lightroom 7.3 (April 2018 release) - The Luxe Lens
