When creaing a PDF from HTML, whenever the letters 'st' appear together a ligature is created when they should be separate letters.
For example:
From this webpage: https://secure.cst.org/portal/en/url/login
How can this be prevented?
Hi Edwardn,
The issue is reproducible with all the browsers at our end as well, please file a bug report with the URL Feature Request/Bug Report Form
Will also notify the same to the Engineering team, so that they can work on a fix/patch and share the resolution with you.
Thanks for your time and patience.
Regards,
Anand Sri.
Hello Edwardn,
We apologize for the inconvenience caused, as per the description above when you are trying to create a PDF from HTML, the letters "st" are changed and a ligature is created, Is that correct?
Try converting the webpage to PDF using a different browser and see if this brings any difference. If the issue persists, please try converting the webpage to PDF on a different user profile and see if the issue is reproducible.
If you still face this issue, please report a bug report to the Engineering team using the URL Feature Request/Bug Report Form
Let us know how it goes and share your findings.
Regards,
Anand Sri.
I tried Firefox, Chrome, and IE and all of them have the same problem. How can I change my user profile?
Hi Edwardn,
Regards,
Anand Sri.
