4 Replies Latest reply on Apr 5, 2018 10:54 AM by danielm93566431
    Photoshop CC 2018 unusably slow, brush lagging, Windows 10
    danielm93566431 Level 1
      Hi Adobe,
      The problem started gradually. With some problem solving I’ve discovered that the larger the document the more the lag. Here’s what I’ve tried so far.
      • Restarting app/Updating
      • Restarting computer
      • Deleting Preferences using “Reset Preferences on Quit”, pain to reformat…
      • Adjusting Memory Usage
      • Adjusting Cache Levels
      • Changed Scratch Disks
      • Saving to my SSD as well as my usual TB drive.
      • Decreasing History Remembered Count
      • Using the program Offline (no Ethernet connected to my PC)
      • Running as Administrator
      • Turning off Font Preview
      • Changing Autosave every n minutes
      • Run with only Photoshop running on my computer
      • Running in 8-bits/channel mode (normal)
      • Purged Memory
      • Disabled Rulers
      I’m exhausted.
      My PC is pretty powerful (it’s 3 years old, but I got it for video work/videogames). Yesterday I had Dell run a full system diagnostic. End all unnecessary processes, clean up all temporary files, etc, etc..
      But Photoshop is still terribly slow even though Efficiency reads at 100%!
      The only features I’ve been using are the brush tool, bucket tool, select tool and the lasso tool, with some fonts such as EmojiOne. On average I have documents 940x15000 (webcomics) with 300 to 800 layers organized in folders. BUT Photoshop CC 2018 still lags a little bit on a tiny 200x300 document with 1-2 layers.
      I also use Photoshop CS5 and it is running smoothly. No lag or issues of any kind. It's not even updated. I would just use it, but I need the EmojiOne font included with Photoshop CC 2018, and I would like to use some of its features (Since I’m PAYING monthly for them).
      Thank you for your help!
        • 1. Re: Photoshop CC 2018 unusably slow, brush lagging, Windows 10
          That should not happen!  Use CC 2018  menu Help>System Info copy and paste info here.....
          • 2. Re: Photoshop CC 2018 unusably slow, brush lagging, Windows 10
            Okay here is my System Info:
            Adobe Photoshop Version: 19.1.3 20180323.r.293 2018/03/23: 1163761  x64
            Number of Launches: 13
            Operating System: Windows 10 64-bit
            Version: 10 or greater 10.0.16299.15
            System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
            Physical processor count: 4
            Logical processor count: 8
            Processor speed: 3592 MHz
            Built-in memory: 32719 MB
            Free memory: 15802 MB
            Memory available to Photoshop: 29442 MB
            Memory used by Photoshop: 71 %
            Alias Layers: Disabled.
            Modifier Palette: Enabled.
            Highbeam: Enabled.
            Image tile size: 1024K
            Image cache levels: 4
            Font Preview: Disabled
            TextComposer: Latin
            Display: 1
            Display Bounds: top=0, left=0, bottom=768, right=1360
            OpenGL Drawing: Enabled.
            OpenGL Allow Old GPUs: Not Detected.
            OpenGL Drawing Mode: Advanced
            OpenGL Allow Normal Mode: True.
            OpenGL Allow Advanced Mode: True.
            AIFCoreInitialized=1
            AIFOGLInitialized=1
            OGLContextCreated=1
            NumGLGPUs=1
            NumCLGPUs=1
            NumNativeGPUs=0
            glgpu[0].GLVersion="4.1"
            glgpu[0].IsIntegratedGLGPU=0
            glgpu[0].GLMemoryMB=2048
            glgpu[0].GLName="AMD Radeon(TM) R9 270"
            glgpu[0].GLVendor="ATI Technologies Inc."
            glgpu[0].GLVendorID=4098
            glgpu[0].GLDriverVersion="15.200.1055.0"
            glgpu[0].GLRectTextureSize=16384
            glgpu[0].GLRenderer="AMD Radeon(TM) R9 270"
            glgpu[0].GLRendererID=26641
            glgpu[0].HasGLNPOTSupport=1
            glgpu[0].GLDriver="aticfx64.dll,aticfx64.dll,aticfx64.dll,amdxc64.dll"
            glgpu[0].GLDriverDate="20150706000000.000000-000"
            glgpu[0].CanCompileProgramGLSL=1
            glgpu[0].GLFrameBufferOK=1
            glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.40"
            glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[2147 483647]
            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
            glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
            glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[16384]
            glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[16384]
            glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[29]
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
            glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
            clgpu[0].CLPlatformVersion="2.0 AMD-APP (1800.7)"
            clgpu[0].CLDeviceVersion="1.2 AMD-APP (1800.7)"
            clgpu[0].IsIntegratedCLGPU=0
            clgpu[0].CLMemoryMB=2048
            clgpu[0].CLName="Pitcairn"
            clgpu[0].CLVendor="Advanced Micro Devices, Inc."
            clgpu[0].CLVendorID=4098
            clgpu[0].CLDriverVersion="1800.7 (VM)"
            clgpu[0].CLBandwidth=1.47312e+11
            clgpu[0].CLCompute=1080.43
            License Type: Subscription
            Serial number: 90970889010523935269
            GUIDBucket:
            Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
            Temporary file path: C:\Users\Test\AppData\Local\Temp\
            Photoshop scratch has async I/O enabled
            Scratch volume(s):
              D:\, 2.73T, 381.2G free
            Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
            Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
            Installed components:
               A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
               ACE.dll   ACE 2017/11/22-18:28:12   79.589342   79.589342
               AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
               AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
               AdobeOwl.dll   Adobe Owl   5.2.11
               AdobePDFL.dll   PDFL 2017/10/31-06:12:59   79.250229   79.250229
               AdobePIP.dll   Adobe Product Improvement Program   7.4.1.109.46827
               AdobeSVGAGM.dll   AdobeSVGAGM   79.588619   79.588619
               AdobeXMP.dll   Adobe XMP Core 2017/07/13-01:06:39   79.160924   79.160924
               AdobeXMPFiles.dll   Adobe XMP Files 2017/07/13-01:06:39   79.160924   79.160924
               AdobeXMPScript.dll   Adobe XMP Script 2017/07/13-01:06:39   79.160924   79.160924
               adobe_caps.dll   Adobe CAPS   10,0,0,6
               AGM.dll   AGM 2017/11/22-18:28:12   79.589342   79.589342
               ahclient.dll    AdobeHelp Dynamic Link Library   3.0.0.6
               AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
               amtlib.dll   AMTLib (64 Bit)   10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8)   1.000000
               ARE.dll   ARE 2017/11/22-18:28:12   79.589342   79.589342
               AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
               AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
               Bib.dll   BIB 2017/11/22-18:28:12   79.589342   79.589342
               BIBUtils.dll   BIBUtils 2017/11/22-18:28:12   79.589342   79.589342
               boost_date_time.dll   photoshopdva   11.1.0
               boost_filesystem.dll   photoshopdva   11.1.0
               boost_signals.dll   photoshopdva   11.1.0
               boost_system.dll   photoshopdva   11.1.0
               boost_threads.dll   photoshopdva   11.1.0
               cg.dll   NVIDIA Cg Runtime   3.0.00007
               cgGL.dll   NVIDIA Cg Runtime   3.0.00007
               CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
               CoolType.dll   CoolType 2017/11/22-18:28:12   79.589342   79.589342
               CRClient.dll   Adobe Crash Reporter Client DLL   1.6.3.0
               dnssd.dll   Bonjour   3,0,0,2
               dvaaudiodevice.dll   photoshopdva   11.1.0
               dvacore.dll   photoshopdva   11.1.0
               dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
               dvamarshal.dll   photoshopdva   11.1.0
               dvamediatypes.dll   photoshopdva   11.1.0
               dvametadata.dll   photoshopdva   11.1.0
               dvametadataapi.dll   photoshopdva   11.1.0
               dvametadataui.dll   photoshopdva   11.1.0
               dvaplayer.dll   photoshopdva   11.1.0
               dvatransport.dll   photoshopdva   11.1.0
               dvaui.dll   photoshopdva   11.1.0
               dvaunittesting.dll   photoshopdva   11.1.0
               dynamiclink.dll   photoshopdva   11.1.0
               ExtendScript.dll   ExtendScript 2017/08/31-12:13:14   81.1150526   81.1150526
               icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
               icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
               icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
               igestep30.dll   IGES Reader   9.3.0.113
               imslib.dll   IMSLib DLL   10.0.0.22
               JP2KLib.dll   JP2KLib 2017/10/31-01:22:04   79.268591   79.268591
               libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
               libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
               libmmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
               LogSession.dll   LogSession   7.4.1.109.46827
               mediacoreif.dll   photoshopdva   11.1.0
               MPS.dll   MPS 2017/10/31-01:22:04   79.588396   79.588396
               pdfsettings.dll   Adobe PDFSettings   1.04
               Photoshop.dll   Adobe Photoshop CC 2018   19.1.3
               Plugin.dll   Adobe Photoshop CC 2018   19.1.3
               PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   8.5.0
               PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   8.5.0.87
               PSArt.dll   Adobe Photoshop CC 2018   19.1.3
               PSCloud.dll                                                   1.0.0.1
               PSViews.dll   Adobe Photoshop CC 2018   19.1.3
               SCCore.dll   ScCore 2017/08/31-12:13:14   81.1150526   81.1150526
               SVGRE.dll   SVGRE   79.586793   79.586793
               svml_dispmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
               tbb.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
               tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
               TfFontMgr.dll   FontMgr   9.3.0.113
               TfKernel.dll   Kernel   9.3.0.113
               TFKGEOM.dll   Kernel Geom   9.3.0.113
               TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
               updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
               VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
               VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
               WinRTSupport.dll   Adobe Photoshop Windows RT Support   19.0.0.0
               WRServices.dll   WRServices Thu June 21 2017 12:26:24   Build 0.22473   0.22473
               wu3d.dll   U3D Writer   9.3.0.113
            Required plug-ins:
               3D Studio 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
               Accented Edges 19.1.3 - from the file “Filter Gallery.8bf”
               Adaptive Wide Angle 19.1.3 - from the file “Adaptive Wide Angle.8bf”
               Angled Strokes 19.1.3 - from the file “Filter Gallery.8bf”
               Average 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Average.8bf”
               Bas Relief 19.1.3 - from the file “Filter Gallery.8bf”
               BMP 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Camera Raw 10.3 - from the file “Camera Raw.8bi”
               Camera Raw Filter 10.3 - from the file “Camera Raw.8bi”
               Chalk && Charcoal 19.1.3 - from the file “Filter Gallery.8bf”
               Chrome 19.1.3 - from the file “Filter Gallery.8bf”
               Cineon 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Cineon.8bi”
               Clouds 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Clouds.8bf”
               Collada 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
               Color Halftone 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Colored Pencil 19.1.3 - from the file “Filter Gallery.8bf”
               CompuServe GIF 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Conté Crayon 19.1.3 - from the file “Filter Gallery.8bf”
               Craquelure 19.1.3 - from the file “Filter Gallery.8bf”
               Crop and Straighten Photos 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “CropPhotosAuto.8li”
               Crop and Straighten Photos Filter 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Crosshatch 19.1.3 - from the file “Filter Gallery.8bf”
               Crystallize 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Cutout 19.1.3 - from the file “Filter Gallery.8bf”
               Dark Strokes 19.1.3 - from the file “Filter Gallery.8bf”
               De-Interlace 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Dicom 19.1.3 - from the file “Dicom.8bi”
               Difference Clouds 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Clouds.8bf”
               Diffuse Glow 19.1.3 - from the file “Filter Gallery.8bf”
               Displace 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Dry Brush 19.1.3 - from the file “Filter Gallery.8bf”
               Eazel Acquire 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “EazelAcquire.8ba”
               Entropy 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
               Export Color Lookup Tables 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Export3DLUT.8be”
               Extrude 19.1.3 - from the file “Standard MultiPlugin.8bf”
               FastCore Routines 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “FastCore.8bx”
               Fibers 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Film Grain 19.1.3 - from the file “Filter Gallery.8bf”
               Filter Gallery 19.1.3 - from the file “Filter Gallery.8bf”
               Flash 3D 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
               Fresco 19.1.3 - from the file “Filter Gallery.8bf”
               Glass 19.1.3 - from the file “Filter Gallery.8bf”
               Glowing Edges 19.1.3 - from the file “Filter Gallery.8bf”
               Google Earth 4 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
               Graphic Pen 19.1.3 - from the file “Filter Gallery.8bf”
               Halftone Pattern 19.1.3 - from the file “Filter Gallery.8bf”
               Halide Bottlenecks 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “HalideBottlenecks.8bx”
               HDRMergeUI 19.1.3 - from the file “HDRMergeUI.8bf”
               HSB/HSL 19.1.3 - from the file “Standard MultiPlugin.8bf”
               IFF Format 19.1.3 - from the file “Standard MultiPlugin.8bf”
               IGES 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
               Ink Outlines 19.1.3 - from the file “Filter Gallery.8bf”
               JPEG 2000 19.1.3 - from the file “JPEG2000.8bi”
               Kurtosis 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
               Lens Blur 19.1.3 - from the file “Lens Blur.8bf”
               Lens Correction 19.1.3 - from the file “Lens Correction.8bf”
               Lens Flare 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Liquify 19.1.3 - from the file “Liquify.8bf”
               Matlab Operation 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “ChannelPort.8bf”
               Maximum 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
               Mean 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
               Measurement Core 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “MeasurementCore.8me”
               Median 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
               Mezzotint 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Minimum 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
               MMXCore Routines 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “MMXCore.8bx”
               Mosaic Tiles 19.1.3 - from the file “Filter Gallery.8bf”
               Multiprocessor Support 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “MultiProcessor Support.8bx”
               Neon Glow 19.1.3 - from the file “Filter Gallery.8bf”
               Note Paper 19.1.3 - from the file “Filter Gallery.8bf”
               NTSC Colors 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “NTSC Colors.8bf”
               Ocean Ripple 19.1.3 - from the file “Filter Gallery.8bf”
               OpenEXR 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Paint Daubs 19.1.3 - from the file “Filter Gallery.8bf”
               Palette Knife 19.1.3 - from the file “Filter Gallery.8bf”
               Patchwork 19.1.3 - from the file “Filter Gallery.8bf”
               Paths to Illustrator 19.1.3 - from the file “Standard MultiPlugin.8bf”
               PCX 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “PCX.8bi”
               Photocopy 19.1.3 - from the file “Filter Gallery.8bf”
               Photoshop 3D Engine 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Photoshop3DEngine.8bi”
               Photoshop Touch 19.0 - from the file “PSDX.8bi”
               Picture Package Filter 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “ChannelPort.8bf”
               Pinch 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Pixar 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Pixar.8bi”
               Plaster 19.1.3 - from the file “Filter Gallery.8bf”
               Plastic Wrap 19.1.3 - from the file “Filter Gallery.8bf”
               PLY 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
               Pointillize 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Polar Coordinates 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Portable Bit Map 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “PBM.8bi”
               Poster Edges 19.1.3 - from the file “Filter Gallery.8bf”
               PRC 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
               Radial Blur 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Radiance 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Radiance.8bi”
               Range 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
               Render Color Lookup Grid 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Export3DLUT.8be”
               Reticulation 19.1.3 - from the file “Filter Gallery.8bf”
               Ripple 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Rough Pastels 19.1.3 - from the file “Filter Gallery.8bf”
               Save for Web 19.1.3 - from the file “Save for Web.8be”
               ScriptingSupport 19.1.3 - from the file “ScriptingSupport.8li”
               Shake Reduction 19.1.3 - from the file “Shake Reduction.8bf”
               Shear 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Skewness 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
               Smart Blur 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Smudge Stick 19.1.3 - from the file “Filter Gallery.8bf”
               Solarize 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Solarize.8bf”
               Spaces 19.1.3 - from the file “Spaces.8li”
               Spatter 19.1.3 - from the file “Filter Gallery.8bf”
               Spherize 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Sponge 19.1.3 - from the file “Filter Gallery.8bf”
               Sprayed Strokes 19.1.3 - from the file “Filter Gallery.8bf”
               Stained Glass 19.1.3 - from the file “Filter Gallery.8bf”
               Stamp 19.1.3 - from the file “Filter Gallery.8bf”
               Standard Deviation 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
               STL 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
               Sumi-e 19.1.3 - from the file “Filter Gallery.8bf”
               Summation 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
               Targa 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Texturizer 19.1.3 - from the file “Filter Gallery.8bf”
               Tiles 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Torn Edges 19.1.3 - from the file “Filter Gallery.8bf”
               Twirl 19.1.3 - from the file “Standard MultiPlugin.8bf”
               U3D 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
               Underpainting 19.1.3 - from the file “Filter Gallery.8bf”
               Vanishing Point 19.1.3 - from the file “VanishingPoint.8bf”
               Variance 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
               Virtual Reality Modeling Language | VRML 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
               Water Paper 19.1.3 - from the file “Filter Gallery.8bf”
               Watercolor 19.1.3 - from the file “Filter Gallery.8bf”
               Wave 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Wavefront|OBJ 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
               WIA Support 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “WIASupport.8li”
               Wind 19.1.3 - from the file “Standard MultiPlugin.8bf”
               Wireless Bitmap 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “WBMP.8bi”
               ZigZag 19.1.3 - from the file “Standard MultiPlugin.8bf”
            Optional and third party plug-ins: NONE
            Duplicate and Disabled plug-ins: NONE
            Plug-ins that failed to load: NONE
            Extensions:
               com.adobe.inapp.purchase  2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
               com.adobe.Butler.backend  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
               Libraries  2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
               New Document  2.1.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_CMDN_EXTENSION_2_1_1_004\fnft.html”
               Start  2.1.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_2_1_1_076\index.html”
               Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
               Export As  3.1.2 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
            Installed TWAIN devices: NONE
            • 3. Re: Photoshop CC 2018 unusably slow, brush lagging, Windows 10
              Your AMD Driver is three year old  see if AMD has a newer Windows 10 device driver available for your AMD Radeon(TM) R9 270.
              Also try turning if  Photoshop Pregerences Performance  Use GPU.  Restert Photoshop some things will be disabled check to see if you still see lag on 300x200 documents with a few layers.
              • 4. Re: Photoshop CC 2018 unusably slow, brush lagging, Windows 10
                Updating the AMD driver did the trick! It's working great now, no lag. Thank you very much! I believe it also fixed my problem with the lasso tool, so I will update that post also.
