3 Replies Latest reply on Jun 27, 2008 12:30 PM by NXTmike
    .flv file is too large
    lost7days
      How do I reduce the size of a 100MB .flv file so it will stream better from my web site?
        • 1. Re: .flv file is too large
          Digital_Mercenary
          That depends greatly on what format the original clip is, and what software you have access to. Hopefully you have AfterEffects CS3. You can render the original clip from AfterEffects as an flv, and decrease the physical dimensions of the clip, the frame rate, and the bitrate. Just from personal experiences, I'd say you could cut the 100M down to probably about 60M.......maybe a little more. If you have AfterEffects, just play with the settings and see what you can come up with. If you don't have AfterEffects or Premier then there really is nothing you can do that I know of.
          • 2. Re: .flv file is too large
            lost7days Level 1
            Thanks for your help, but the file I have is already in .flv format. I don't have the source video. Is there some way to use Flash to make the file easy to stream over the Internet?
            • 3. Re: .flv file is too large
              NXTmike
              I still think you can import a .flv file into After Effects.
