1. Re: After Effects file will not open with ITC Officina Serif/Sans
samd13031816 Apr 5, 2018 12:12 PM (in response to mabely96631992)Same thing is happening to me with "Gotham" and the entire Gotham family. I've been chasing it around all day. Similarly, I can use the font in any other program.
EDIT: I take this back. I CANNOT open the font in Premiere, either. Only Photoshop.
2. Re: After Effects file will not open with ITC Officina Serif/Sans
Dave LaRonde Apr 5, 2018 1:10 PM (in response to mabely96631992)Ha! You got sucked into getting the latest update to CC 2018, huh?
Well, the geniuses at Adobe broke the ability to read certain Postscript typefaces. No word on a fix yet -- they're still scratching their heads over exactly what they did to break it.
The only good way to get them to work -- revert to an earlier version.
3. Re: After Effects file will not open with ITC Officina Serif/Sans
mabely96631992 Apr 5, 2018 2:36 PM (in response to mabely96631992)Thanks Dave...got suckered in, like many, couldn't reinstall CS6 on High Sierra...hope they fix the code, this may cause problems with clients.
M
4. Re: After Effects file will not open with ITC Officina Serif/Sans
Dave LaRonde Apr 5, 2018 3:23 PM (in response to mabely96631992)Unless your clients send you AE project files in this most up-to-date CC 2018 version, I don't see why you couldn't use CC 2017... which works on High Sierra.
That's what I use -- I stay a version behind to avoid bugs & bad surprises.
