4 Replies Latest reply on Jun 19, 2008 6:10 AM by jtncarter
    Navigation Pane
    jtncarter
      We are trying to work around the map file to link in an application. To do this we would like the navigation pane to open when a direct page is pulled in the browser. Is there a simple way this can be done?
      Example: One of my topics is called suspensions.html I would like to be able to directly link to suspensions.html inside the application and when the page is displayed it also pulls the navigation pane with it. I know I can place a javascript in to accomplish this but I don’t want to have to do that for each page every time I publish.
        • 1. Re: Navigation Pane
          Linux Rules Level 2
          Hello jtncarter -
          Do you call the Help from within the app? How?
          We use a Help icon or hot key that tied to a JavaScript that reads the app "main" frame and passes that to the compiled Help startup html file - no "typical" App-to-RoboHelp map file involved. The JS is part of the app not the Help - I have nothing to do with it other than STRICT file naming to follow the app.
          Using your post, we would have:
          Application screen with Help button (calls Help): ../suspension/suspension.htm
          Help calls to: ../help/startpage.htm
          Help topic appended to call: ../help/suspension/suspension.htm
          When in the app, on the "Suspension" screen, click the Help icon to launch context help for "Suspensions" along with the navigation pane.
          Hope that help.
          Regards,
          GEWB
          • 2. Re: Navigation Pane
            jtncarter Level 1
            Yes its a big help. The problem is I have files in folders and that is creating a problem.
            I have it linked in the application we are developing as...
            Desktop\help\!SSL!\webhelp\help.htm#path\inspections\viewing_inspections.htm
            The TOC pulls but I get a "page cannot be displayed" for the viewing_inspections.htm
            • 3. Re: Navigation Pane
              Linux Rules Level 2
              Hello jtncarter -
              Having files in folders is not the problem - location of the folders and path linked from the app may be your problem.
              Place your generated Help in a second level folder under the app (root) such as:
              (root)/
              (root/help/
              (root)/help/topic/
              Then have the app call:
              ../help/(yourstartpage).htm(yourtopicappendmethod)
              If, as you replied, you are calling "Desktop\help\!SSL!\webhelp\help.htm#path\inspections\viewing_inspections.htm" it will never work because you are calling a file that exists only on your workstation desktop.
              Regards,
              GEWB
              • 4. Re: Navigation Pane
                jtncarter Level 1
                I guess yesterday was just not my best day.
                Thanks but until I learn the difference between a ( \ ) and a ( / ) nothing is going to work.
                After I changed everything to ( / ) it worked fine. Thanks for your help.
