• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
3
Photoshop brush stroke moving canvas?
Community Beginner ,
Apr 07, 2018 Apr 07, 2018
Hello all, whenever I try to make a brush stroke in Photoshop CC 2018, it moves my canvas as though I'm using the hand tool rather than actually putting down a brush stroke. I've tried uninstalling and reinstalling my Intuos3 tablet drivers, uninstalling and reinstalling Photoshop with all of my preferences removed, I've tried resetting my tools to see if that would have any effect and have had absolutely ZERO luck.
I did a test run with Krita to make sure it wasn't a tablet issue and my brush strokes worked 100% fine in that program, so I think this is a Photoshop specific problem. If anyone has any pointers, please, please, please, help. Any advice would be greatly appreciated as this is an issue that only recently came up and I haven't the slightest idea why it might be happening.
Cheers.
Views
46.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Apr 26, 2018 Apr 26, 2018
Hi
No need for any of this now. Microsoft have now issued an update to fix the issue that they caused . See link in this page from Adobe:  Cannot paint with stylus when zoomed in on image | Windows 10
Dave
Votes
Translate
Translate
Adobe
replies 117 Replies 117
Advisor ,
Sounds like the KB4089848 problem.  This Windows 10 update has caused the canvas dragging you describe. You can achieve  temporary relief from the problem by uninstalling the Windows update KB4089848 and then pausing the update process (this will give you a month of no updates). We  are all hoping that a Windows Update will be found to correct this problem.  If you look through the list of posts you will find  quite a few about this.
Votes
Translate
Translate
Report
Report
Community Expert ,
David, this should be fixed with Photoshop 19.1.3 update from a couple of days ago.
Votes
Translate
Translate
Report
Report
Advisor ,
Thanks, Trevor.  Unfortunately, my instance of the problem caused by KB4059848 has not been fixed by 19.1.3. I have that update and the problem persists.  I have had to resort to using the WinTab option helpfully mentioned by you and others (because I want to be set for the Spring Creators Update expected next week). I have seen nothing from Adobe on this problem.  Incidentally, I have checked my Painter 2018 preferences and I see that software explicitly offers WinTab.
David
Votes
Translate
Translate
Report
Report
I don’t understand why there isn’t a bigger outcry over this, it’s really frustrating to have sit around and wait for the bug to get fixed. Funnily enough I didn’t have the problem until 19.1.3 and it’s really messing up my workflow. I‘m really frustrated with this.
Votes
Translate
Translate
Report
Report
Thank you so much David for your insight~! Trevor, I also have the most updated version of Photoshop installed on my machine and the problem is definitely persisting. I'll give the windows update pause a try, and may try the WinTab option you suggested as well. Here's hoping something works in the meantime, because I've been losing my mind trying to get this to function properly @_@;.
Votes
Translate
Translate
Report
Report
Community Expert ,
Thanks for letting us know that the 19.1.3 update did not fix the issue.  We were told that it would, so that is useful information.  If using WinTab instead of Windows Ink does the job, then please let us know.
One thing I can tell you is that I have Windows 10 and an Intuos 4, and have never experienced the issue.  In fact I just tried to force it and was unable, so I am wondering what set of circumstances causes it to happen?
Votes
Translate
Translate
Report
Report
Guest
Apr 11, 2018 Apr 11, 2018
I just got the Windows update this morning, and I now have the same issue. I hope I can unistall the last Windows update.
Just a few hours ago Photoshop was working perfectly, so that must be it.
Edit : Unistalling KB4099989 and KB4093112 solved it for me, thanks all
Votes
Translate
Translate
Report
Report
Community Expert ,
No need to uninstall the Windows update. Just do the following:
1. Use notepad to create a text file and type in :
UseSystemStylus 0
2. Save the file as PSUserConfig.txt in the following location
C: > Users > Username > AppData > Roaming > Adobe > Adobe Photoshop CC 2018 > Adobe Photoshop CC 2018 Settings
3. Go to the Wacom tablet properties and for Photoshop under Mapping  uncheck "Use Windows Ink"
That is it - all should now work well
Dave
Votes
Translate
Translate
Report
Report
New Here ,
Hi Dave, thanks. I did 1 and 2 and they worked. I didn't need to do step three.
Do you think that this issue will resolve itself with the next update? Or should I just keep that text file there for good?
Ben
Votes
Translate
Translate
Report
Report
This fixed my issues after the update, thank you!
Votes
Translate
Translate
Report
Report
New Here ,
Hi Dave, im wondering if you please can help me, i tried to do the solution you said, but i don't have a Roaming folder, im a PS CC 2015 user and also a Genius tablet owner, do you have some solution for me please?
Thank you
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi
I am not sure why you are not seeing the standard three folders in AppData. Normally you would see these :
I'll copy in JJMack    to see if he can help. He has great knowledge of Windows.
Dave
Votes
Translate
Translate
Report
Report
Gaiantt: Open Windows Explorer, navigate to the user folder where the Roaming folder should be, and try making sure "Hidden Items" is checked at the top of the Explorer toolbar:
Votes
Translate
Translate
Report
Report
New Here ,
Hi and thank you . I checked it and it doesn't appear neither 😕
Votes
Translate
Translate
Report
Report
Hey GaiantT!
Maybe try to open the roaming folder through entering %appdata% in the windows search bar
Votes
Translate
Translate
Report
Report
New Here ,
Apr 12, 2018 Apr 12, 2018
Hi and thank you, but did'nt work neither
Im litterally stressed out with this haha, also this start happening since yesterday's evening, should i uninstall something?
Votes
Translate
Translate
Report
Report
New Here ,
Thanks guys, your solution with the .txt file and pointing to the hidden folders was spot-on! Worked without having to uninstall the Windows 10 updates mentioned! Big thanks!
Votes
Translate
Translate
Report
Report
Had the same problem as described above.
Only after uninstalling KB4093112 I got it fixed.
Still. Annoying.
Regards
JP
Votes
Translate
Translate
Report
Report
Thanks Dave for this solution. I reinstalled the removed Windows Updates and did your steps above.
I had some trouble finding the step 3 setting, but I found it under the Calibrate tab:
Votes
Translate
Translate
Report
Report
New Here ,
Thank you
Votes
Translate
Translate
Report
Report
Community Expert ,
Dave, I did your fix - thanks. I noticed this affected all my installed CCs, but not on CS4. CC2015 (32-bit) had the Hand tool itself broken - dragging it made the scroll bars turn white. Everything seems to be copacetic now, except 2018 is the only version with Stylus dynamics. If I drop copies of the text file into the appropriate folder, will that bring the dynamics back? What about CS4?
Votes
Translate
Translate
Report
Report
New Here ,
This totally worked, and actually improved the stylus performance, at least in my case because i would work with the "windows ink" activated and would always malfunction while working, like opening optical keyboard and so.
Really, thank you
Votes
Translate
Translate
Report
Report
New Here ,
Thanks Dave!
Worked for me.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 14, 2018 Apr 14, 2018
Hi Dave, tried this with not much success. The pen works but PS is not recognizing pen pressure. I am using a Surface not a wacom tablet. Thanks, this is incredibly infuriating. Tried installing a wintab driver but no clue where it went
Votes
Translate
Translate
Report
Report
