Hey guys,
i have a daunting task infront front of me and I am thinking a smarter way would be a script. Problem I don’t code.
I need to create a whack of hex swatch png files (2000px by 2000px - 72dpi) for a project. I have a bunch of upc codes, and their hex values separated in a csv table and I need to use the hex value to fill the square and save the file using both fields as part of the filename.
so so I have a the 12 digit upc say 057896543001 and the hex value for that of say 325647 ...... I would need a coloured square png with the fill color of 325647 and a file name of 057896543001_325647.png
manually it is taking a minute or so for each file ..... any direction or help would be greatly appreciated In building a script to automate this process.
cheers,
james
You could try this, it needs a csv file in the format:-
upc,hex
057896543001,325647
057856543001,ff0000
957896543001,ffff00
#target photoshop;
main();
function main(){
var csvFile = File.openDialog("Open Comma-delimited File","comma-delimited(*.csv):*.csv;");
if(csvFile == null) return;
var outputFolder = Folder.selectDialog( "Please select output folder");
if(outputFolder == null ) return;
csvFile.open("r");
var data = csvFile.read().split("\n");
csvFile.close();
app.preferences.rulerUnits = Units.PIXELS;
app.preferences.typeUnits = TypeUnits.PIXELS;
var doc = app.documents.add(2000, 2000, 72, null, NewDocumentMode.RGB, DocumentFill.WHITE);
for(var a in data){
if(data.length < 12) continue;
var line = data.split(",");
if(line[0].replace(/^\s+|\s+$/g,'').match(/^[a-zA-Z]/)) continue;
var upc = line[0].replace(/^\s+|\s+$/g,'');
var hex = line[1].replace(/^\s+|\s+$/g,'');
var saveFile = File(outputFolder + "/" + upc + "_" + hex + ".png");
var FillColour = new SolidColor;
FillColour.rgb.hexValue = hex;
activeDocument.selection.selectAll();
activeDocument.selection.fill(FillColour);
activeDocument.selection.deselect();
SavePNG(saveFile);
app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
function SavePNG(saveFile){
pngSaveOptions = new PNGSaveOptions();
activeDocument.saveAs(saveFile, pngSaveOptions, true, Extension.LOWERCASE);
