1. Re: I set up Dual Monitors - Then I lost "Scrubby Zoom"
Mylenium Apr 8, 2018 1:12 AM (in response to CoachDM)Nothing to dance around: Your dual setup simply exhausts all hardware resources of your graphics card and acceleration features are levelled down or turned off. Unless you get a more powerful card, this won't change.
Mylenium
2. Re: I set up Dual Monitors - Then I lost "Scrubby Zoom"
davescm Apr 8, 2018 1:36 AM (in response to CoachDM)Are your two monitors using a single GPU, which is recommended?
Photoshop works on multiple monitors, I use three, but is known to have issues with multiple conflicting GPUs.
Dave
3. Re: I set up Dual Monitors - Then I lost "Scrubby Zoom"
CoachDM Apr 8, 2018 10:29 AM (in response to Mylenium)Thank you for the info. So there is no workaround? Nothing to turn off/on or adjust in regards to the card and performance. I'm running a GeForce GTX 1060.
4. Re: I set up Dual Monitors - Then I lost "Scrubby Zoom"
CoachDM Apr 8, 2018 10:31 AM (in response to davescm)Yes. I believe I am only running a single GPU for both monitors.
I have a GeForce GTX 1060.
Is there a way to check or adjust so that the feature comes back?
5. Re: I set up Dual Monitors - Then I lost "Scrubby Zoom"
Trevor.Dennis Apr 8, 2018 12:10 PM (in response to CoachDM) -
6. Re: I set up Dual Monitors - Then I lost "Scrubby Zoom"
davescm Apr 8, 2018 12:10 PM (in response to CoachDM)You can check the GPU in Help>System info - you should only see 1 GL GPU and 1 CL GPU of either show 2 then you will need to force the use of a single GPU
See this for more info Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues in particular section 7
Dave
7. Re: I set up Dual Monitors - Then I lost "Scrubby Zoom"
CoachDM Apr 8, 2018 5:40 PM (in response to Trevor.Dennis) -
8. Re: I set up Dual Monitors - Then I lost "Scrubby Zoom"
CoachDM Apr 8, 2018 5:44 PM (in response to davescm)Thanks!
It has the CL GPU listed as 1.
It has the GL GPU listed as 2.
I followed step 7 in the directions you provided.
In my NVidia control panel there is not option for "Change the preferred graphics processor to High-performance NVIDIA processor."
I followed step 8 and disabled the Intel Graphics card.
It's still not working and the system info still has it listed as "2" under GL GPU.
