So I have a 2 minute video clip, I want to export 1 single frame as a RAW, JPG, or PNG (I DONT CARE) how the heck to do you do this. I see the capture frame option which i have done 50 damn times already and the only thing that happens is some counter increasing but that does do me a damn bit of good if I can't get at the image.
So how do you do this???
Here is a screen shot of the counter -> http://prntscr.com/j2hvod
Hi Wayne,
Use the play head to scrub through the video > select the frame > select capture frame in the pull down menu to the left of the gear icon > select capture frame > go back to grid view and you should see the frame with a .jpg extension. You can edit and export as you wish.
And also consider-
Lightroom stacks the capture frame with the video clip (indicated by the number on the thumbnail). To view the capture frame, expand the stack in the Grid view of the Library module. Be sure you are not viewing Previous Import in the Catalog panel.
Thank you guys it appears that after I capture the image it didn’t reappear in my library although I found 10 copies of it in the directory were the raw files are kept
Wayne,
You must be looking at thumbnails in the Library Grid View
See this section of the help for how to view the frame:
How to work with video in Lightroom Classic CC
I have this same issue. I have 3 images in a stack. If I unstack they do not appear as separate images. Only if I go back and import again are they seen and that requires me to do this each time. Is there something preventing the unstack images appearing adjacent each other when I unstack without the need to re-import?
Yes I did see the same problem but only on the first occassion that I captured a still from a video! (Maybe a bug?)
On the second try it was successful! I could even expand the stack on the Film-strip (ass in my screen-clips).
Expand >
After capturing a 'Still' go into Grid view and you may find that the JPG is in the catalog, and does not need to be imported.
And then there is the 'Universal Panacea' for quirky problems - PREFERENCES RESET
