Hello everyone...
This is my biggest problem in Animate AS3 ever. So the problem is-
I have 8 SWFs which have separate topic in each and one main SWF file and i want to connect all of them together like-
Firstly i open Main SWF then it shows all the 8 topics name with each button. i used script from code snippets which is 'Click to load/unload SWF' and i assigned all the SWF as it required to open. I have created a button in each SWF to go back to main SWF using same code as i mentioned.... It is working properly but i realized that each time i click to open new SWF, it overlape on old one and when i open multiple times all SWFs, it become very heavy and get legging and hangs very much, consumes more memory...
So what can i do to load new SWF and unload all previous SWFs by clicking on same button in each SWF ???????
Please give some idea with whole script which i have to paste with button name and file name(u can assume any button name and file name).
As i don't have enough knowledge about writing manual code.
Please give some positive response.
Thanks....
use one loader for all your loads (eg, loader) and use:
if(loader.content){
loader.unloadAndStop();
loader.load(new URLRequest(whatever));
Sir,
Thanks for your reply... But can you please give detailed script for just one file ???
I mean, full script... Not just a part....
remove the code in your loaded swfs that unloads them.
in your main swf youl would use something like:
var loader:Loader=new Loader();
addChild(loader);
// if you're using movieclip buttons topic_0, topic_1 etc to load swfs topic_0.swf, topic_1.swf etc
for(var i:int=0;i<8;i++){
this['topic_'+i].ivar=i;
this['topic_'+i].addEventListener(MouseEvent.CLICK,loadF);
function loadF(e:MouseEvent):void{
if(loader.content){
loader.load(new URLRequest('topic_'+MovieClip(e.currentTarget).ivar+'.swf'));
These are the actual files which you can see how is it working...
So when i open again and again these files it gets heavier and lags...
please describe code....
use the code i suggested. change button names and swf names to match the code, or change the code to match your button and swf names.
i pasted the code but nothing happen... Please describe me where i have to paste button name and SWF's name?
addChild(loader);
this['topic_'+i].ivar=i; // this['topic_'+i] are your button names
if(loader.content){
loader.load(new URLRequest('Smart Achivement'+MovieClip(e.currentTarget).ivar+'.swf'));
It's showing this error....
TypeError: Error #1010: A term is undefined and has no properties.
at SmartAchivment_fla::MainTimeline/frame1()
I pasted this code-
addChild(loader);
this['button_2'+i].ivar=i; // this['topic_'+i] are your button names (Button Name which i have to press to go to other SWF =button_2
this['button_2'+i].addEventListener(MouseEvent.CLICK,loadF);
if(loader.content){
loader.load(new URLRequest('Index'+MovieClip(e.currentTarget).ivar+'.swf')); (SWF name which is Main SWF, i have to load = Index.swf)
your button names are incorrect.
do you have movieclips named button_0, button_1 etc?
and what's ButtonHome supposed to do?
a little suggestion, GreenSock is a wonderful library to load multiple swf with maximum of optimization
'ButtonHome' will load main SWF.
again, remove the code in your loaded swfs that unloads them.
