3 Replies Latest reply on Aug 18, 2008 7:36 AM by RoboColum(n)
    RoboServer 7 - Implementation questions need technical assistance
    pjv@gs Level 1
      We have the server and RoboServer 7 application sort of installed. I need a technical person who can talk to my technical person to ensure that installation is done correctly. (I'm the technical writer on the team).
      Also, need to understand how to migrate existing help files from the current application server to the RoboServer 7 without losing F1 links.
        • 1. Re: RoboServer 7 - Implementation questions need technical assistance
          RoboColum(n) Level 5
          It would be best if you (or they) posted a specific question here. Either that, or contact the Adobe Support Team. If you have the app installed it hard for anyone here to say you have done it correctly without knowing more detail.
          With regards to the F1 help, check out this link. It refers to WebHelp but also applies to WebHelp Pro.
          • 2. Re: RoboServer 7 - Implementation questions need technical assistance
            pjv@gs Level 1
            Colum
            Thanks for your answer. I can't get my support group to read the documentation that is available so I can't tell you what questions need to be answered. I've got my manager working on getting a conference call with Adobe support and our guys because that's the only way this will ever get implemented. Problem is RoboServer7 and RoboHelp 7 are not supported by Goldman Sachs so it hard to get internal SAs to support these applications, which leaves my team hanging.
            Regarding the F1 help, I'm using FlashHelp. We've already implemented F1 using the full path on the server to link the help topic to the window as they didn't want to use map #s. Question is how to move the application help, which includes the F1 help pathing, from its current location on the application server to the server where RoboServer7 is installed without losing all of F1 links? One of my guys thought there might be way to do it with relative path linking?
            I'm also thinking that we should migrate to FlashHelp Pro once we get RoboServer 7 up and running.
            • 3. Re: RoboServer 7 - Implementation questions need technical assistance
              As far as F1 help is concerned I'd always recommend using relative paths. As far as the RH server is concerned, I think the article link I sent also applies although Peter Grainge doesn't use RH Server so this has not been tested. Therefore not using mapids is still an option.
              If you are using FlashHelp output you will HAVE to upgrade to FlashHelp Pro output to publish to the RH Server.
