14 Replies Latest reply on Jul 12, 2018 9:01 AM by ipatinoal
    Captivate 2017 videos on slides randomly have the ends cut early (cut off).
    JohnJohnstone AtWork Level 1
      Hey everyone,
      I've seen it posted before for older versions but the issue still remains so I'm going to re-ask the question. Our team will create a Captivate file with a few slides that contain video clips. When published as HTML 5, these video slides work fine. When publishing as video the ends of the video clips within the slide will get cut off. The amount of time cut off seems to be random. I have tried the following:
      • extending the slide to be longer than the video
      • changing the frame rate of the video (30fps is recommended)
      • turning advance compression on and off
      • adding extra slide frames to the beginning
      • changing the key-frame distance in the source video
      • renaming the source video
      • recreating the slide from scratch.
      • inserting the video into a new project
      • Changing the project skin and the player skin.
      • It happens to event and multi-slide synced videos
      • It can happen in a template based file or completely blank file (at one point I thought it was the template that we use but the issue finally happened in a blank file. It seems to be randomly occurring issue so far).
      • We are using h.264 video at 30 fps as recommended.
      It's really frustrating as we need to have a HTML5 and Video version of all of our material. Right now we have to video capture from the HTML5 version. A real pain.
      I've spent a few hours turning things on and off, trying to reduce the number of variables and I'm pretty sure it's something deep in Captivate and not the video files or anything we've done to our Captivate file. And the fact that in a brand new, blank captivate file the multiple videos we've tried have a 90% chance of having the ends cut off tells me that there's something wrong in the code. Even the same video file can sometimes work and sometimes not.
      Anyone have any ideas?
        • 1. Re: Captivate 2017 videos on slides randomly have the ends cut early (cut off).
          Lilybiri MVP & Adobe Community Professional
          If you don't get an answer, that means the problem could be not appearing that way for other users? I rarely use video as output, I want realy eLearning which needs interactivity
          However, I pop in because of this sentence:  ....in a template based file ....
          Are you talking about a file created based on a cptil file? Because at this moment there is a serious bug with cptl-files, I would recommend never to use them.
          For the sake of (hopefully) users that could help you: which version are you using and on which OS?
          • 2. Re: Captivate 2017 videos on slides randomly have the ends cut early (cut off).
            Thanks for popping in. We do a bit of interactivity as well but we produce a video version both for archival as well as a proofing workflow. It's also great if someone has issues accessing the LMS, they can go to our video site and watch it there.
            I actually got on a call with Captivate support and ran through some troubleshooting. The issue happens whether or not we use a template file. We create our own templates and I thought that could be the issue.... something in our template could be causing the issue. But that's not the case. The tech that consulted with me could reproduce the same issue in a blank captivate project. That rules out templates of any kind being the culprit.
            Here's an oddity though. If the video was placed on a slide with no slides before it, it worked fine and did not truncate the video. If there was a slide before it, the video output would be truncated. This is in a blank project... as vanilla as could be mind you. This happens both in the windows and mac version of Captivate 2017 too (it's the most recent build).
            Captivate support has bumped up the issue and said they should have some more info within 48 hours (I've heard that before unfortunately). But I do expect some response. I'll keep the thread informed.
            I really appreciate your input btw. Any help to narrow this down makes a difference!
            • 3. Re: Captivate 2017 videos on slides randomly have the ends cut early (cut off).
              It looks like a loading issue, from what you explain about slides. SImiar isse can happen with long audio files which hae to be loaded on enter of a slide. There a possible solution is to delay the audio file a little bit on the slide. Did you try that for the videos? You could add a static image to bridge the gap. Just an idea.
              • 4. Re: Captivate 2017 videos on slides randomly have the ends cut early (cut off).
                If you read my laundry list of the solutions I tried, your suggestion is in there. I pushed the video forward a few frames which didn't help. I also put a few frames at the end in another test which also didn't help. The video in question is 34 sec (very short). We have many courses with videos that are much longer that seem to work fine. Length of video doesn't not seem to be a factor.
                • 5. Re: Captivate 2017 videos on slides randomly have the ends cut early (cut off).
                  Sorry to have missed that, my apologies. I will leave you to video experts, or perhaps Adobe will sort a solution?
                  • 6. Re: Captivate 2017 videos on slides randomly have the ends cut early (cut off).
                    RodWard Adobe Community Professional & MVP
                    Did you encode these videos using Adobe Media Encoder or some other encoding tool.  If not AME, please try that tool.  Sometimes video issues are related to small differences in encoding.  Adobe software tends to prefer its own encoding solutions.
                    • 7. Re: Captivate 2017 videos on slides randomly have the ends cut early (cut off).
                      Yeah, I only use AME. And captivate is barely an Adobe product in many ways lol. I had to beg their development team to recommend the best codec settings to use. The most specific they would give me is to use H.264 at 30 fps. I've handed over the some of the videos we use to their support team. It's not the video content as sometimes it will cut them off and sometimes it won't. It depends on what is before or after the slide containing the content.
                      • 8. Re: Captivate 2017 videos on slides randomly have the ends cut early (cut off).
                        Oh no problem. It's a long list. I posted that list to save any other poor soul that is having the same issues so they can skip some of the steps I did. I appreciate the input!
                        • 9. Re: Captivate 2017 videos on slides randomly have the ends cut early (cut off).
                          I just got an email back from Adobe support (20 days after my phone call with them) and they said that it's a known bug and it's on the list to fix. I was initially impressed that they even followed up and then doubly so when someone called back to say the same. I figured my issue was lost in the wind. I told them I appreciated the follow up and I would look forward to any updates (which they promised they would give me).
                          The next email I got a few minutes later was that my issue had been CLOSED. What the hell.
                          Just to be clear,
                          This issue is NOT RESOLVED because this issue is NOT FIXED. This is a mission critical feature for us that does not work. Putting it on a pile of things to fix later is not a resolution. It's a way to improve your customer service score internally.
                          And the issue being closed means there's no link to me once (or if) the problem is corrected. The email and phone call to me was only to close the issue and get it off the list. I'm so done with this team. They are literally doing the minimum to support their customers.
                          • 10. Re: Captivate 2017 videos on slides randomly have the ends cut early (cut off).
                            Erik Lord Adobe Community Professional
                            Two thoughts:
                            1. Don't assume 30fps is the only option. I think CP plays at...15fps by default? Or did when it was for Flash? Or maybe I'm thinking of Flash.... At any rate, maybe can't hurt to change the FPS output and see if the result changes.
                            2. Interesting 'depends on what is before or after the slide'. As you know, if you have interactive content on CP slides, that won't 'work' as video. I don't know if I've ever tried to publish an interactive CP as a video, but I bet the inability to render the interactive components as they're intended could be a factor in the issue (?).
                            So are your before/after slides interactive? Or are they just straightforward presentation slides with no buttons, etc?
                            If yes to buttons, etc...maybe make a copy of the piece and remove all the interactive pieces that stop the timeline, then publish to video. Same issue? Or is the issue resolved? (not that it really helps if you need interactive slides, but it helps define the problem)...and in which case you could work-around it by using CP or Camtasia to record someone going through the piece and publish that as a video...though, granted, not as time efficient.
                            • 11. Re: Captivate 2017 videos on slides randomly have the ends cut early (cut off).
                              The 30fps number was from Deep Raushan Roy the Sr. Technical Support Consultant when I asked for the best possible format / codec to use for smooth streaming w/o buffering. We no longer use flash due to the many issues we ran into. But as to your suggestion, we tried lower fps (including 15) with no joy.
                              We tried putting slide content before and after the video slide. When we noticed that it had an effect on the cut off, we then started with a blank captivate slide with the 1st slide being totally blank, 2nd slide with video content and 3rd slide being blank again. So they were straight forward with no content whatsoever.
                              It's just a coding bug according to Adobe.
                              At this point we use Snagit or Screenflow to capture our presentations.
                              You were thinking exactly down the lines we tried.
                              • 12. Re: Captivate 2017 videos on slides randomly have the ends cut early (cut off).
                                ipatinoal Level 1
                                Hi John,
                                I'm currently working on a project that keeps acting like yours...there are around 10 slides with short clips, and 2 of them keep getting cut. It´s driving me crazy and the client is getting upset.
                                Have you had any feedback from the captivate support team?, I´ll appreciate any input or workaround if you have it.
                                Thanks in advance!
                                • 13. Re: Captivate 2017 videos on slides randomly have the ends cut early (cut off).
                                  Hey there ipatinoal,
                                  The only workaround was to use snagit (windows app) or screenflow (mac) to literally screen capture the preview that plays from Captivate. We have heard NOTHING from Adobe on this. It's persisted through every hotfix for both Windows and Mac platforms (we use both). It's been a huge disappointment.
                                  • 14. Re: Captivate 2017 videos on slides randomly have the ends cut early (cut off).
                                    ipatinoal Level 1
                                    Thanks for taking the time to reach back and so fast!. I really appreciate it.
                                    The workflow unfortunately isn't a choice for us. I´ll take a chance of luck and try an awful trick..add some sort of "noise" at the end of the video to increase its length, and pray captivate keeps failing so it cuts-off the noise and not the part of the video that I need to be seen.
                                    It´s unbelievable that a problem like this stays unfixed for so long..I´ll try and reach adobe and let you know how that goes.
