• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
2
The pencil is moving the canvas instead drawing only on Photoshop CC 2018
New Here ,
Apr 11, 2018 Apr 11, 2018
I've been recently going through a problem with photoshop, on my main computer, after the recent update (19.1.3). I'm using a Wacom 13HD and Photoshop CC 2018.
When I want to draw, I have to hold still my pen for a couple of seconds before it want to properly draw a line. If I don't wait, it just move the canvas instead. I've tried on different drawing programs (Paintoll SAI, Paint and Illustrator CC 2018) and even on another computer with the same programs, and it works perfectly fine. No matter what version or settings I choose either for the Wacom 13HD or Photoshop, the problem is the same.
Thanks for the response.
TOPICS
Windows
Views
37.4K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Apr 27, 2018 Apr 27, 2018
Hello, and here’s a solution without Registry editing: Cannot paint with stylus when zoomed in on image | Windows 10
Votes
Translate
Translate
Adobe
Community Expert ,
Hi
The latest windows update (KB4093112)  has caused an issue with the Wacom tablet and Photoshop.
You can either - undo the update
or
Do the following:
1. Use notepad to create a text file and type in :
UseSystemStylus 0
2. Save the file as PSUserConfig.txt in the following location
C: > Users > Username > AppData > Roaming > Adobe > Adobe Photoshop CC 2018 > Adobe Photoshop CC 2018 Settings
3. Go to the Wacom tablet properties and for Photoshop under Mapping  uncheck "Use Windows Ink"
That is it - all should now work well
Dave
Votes
Translate
Translate
Report
Report
New Here ,
How can I undo the update?
And I don't know if that is the problem, cuz I didn't instalete a new update...
I really don't know much about this all (I only started a year ago)
Votes
Translate
Translate
Report
Report
Community Expert ,
My recommendation would be to leave the Windows update alone and to install the PSUserConfig,txt file as described in the previous post
Dave
Votes
Translate
Translate
Report
Report
New Here ,
Apr 16, 2018 Apr 16, 2018
thank you thank you thank you thank you thank you thank you
I was going crazy!!!
Votes
Translate
Translate
Report
Report
New Here ,
There wasn't an appdata folder under any usernames, but when I found it under program files instead, there is no settings folder in my 2018 Photoshop files. I tried to make a Settings folder just to see, nothing. There is a "Configuration" folder, no results either.
Would love your help!
Votes
Translate
Translate
Report
Report
New Here ,
May 07, 2018 May 07, 2018
use (show hidden files and folders). app data is hidden folder.
Votes
Translate
Translate
Report
Report
Community Beginner ,
I don't quite understand step 2.
I'm not given the option of being able to save the file in a particular location.
Votes
Translate
Translate
Report
Report
Guest
Apr 12, 2018 Apr 12, 2018
Hi
You need to go to File Explorer > View and put a check mark in Hidden items
Votes
Translate
Translate
Report
Report
Apr 13, 2018 Apr 13, 2018
When I try to save the file and open the Adobe folder I can't find "Adobe Photoshop CC 2018".
Am I doing something wrong?
Completely new to Windows by the way.
Votes
Translate
Translate
Report
Report
New Here ,
That really worked for me. Many thanks Dave.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 15, 2018 Apr 15, 2018
Hello I’ve been have the same trouble however i don’t know how to use notepad and when I do uncheck the windows ink box it just takes away my pressure sensitivity where do I go for accessing notepad?
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi if you disable Windows Ink you need to use the PSConfig.txt file to restore pressure sensitivity.
You will find notepad in Windows Accessories
Alternatively use the fix posted by Microsoft. In either case type exactly what is posted
Dave
Votes
Translate
Translate
Report
Report
New Here ,
Hi
I followed all of u steps and it were working well, but i turn off the pc and the mistake appear again
Votes
Translate
Translate
Report
Report
New Here ,
Apr 18, 2018 Apr 18, 2018
That did the trick
Votes
Translate
Translate
Report
Report
New Here ,
Apr 19, 2018 Apr 19, 2018
I can't seem to find Adobe Photoshop CC 2018 in the Adobe folder. Help would be appreciated! (I have Photoshop installed)
Votes
Translate
Translate
Report
Report
Guest
You may need to enable hidden items in file explorer
The path should be
C:\Users\Your Name\AppData\Roaming\Adobe\Adobe Photoshop CC 2018\Adobe Photoshop CC 2018 Settings
Votes
Translate
Translate
Report
Report
New Here ,
The path should be
Nope. Nothing. The thing is the Adobe folder isn't in Roaming. It has other adobe products I have installed but no Photoshop. (CC Animate not showing up either).
Votes
Translate
Translate
Report
Report
Guest
That's strange, can you post your system info, in Photoshop go to Help > System Info and copy and paste the info here
Votes
Translate
Translate
Report
Report
New Here ,
It's in Finnish (I have no idea how to switch language sorry.)
Adobe Photoshop -versio: 19.1.3 20180323.r.293 2018/03/23: 1163761  x64
Käynnistyskerrat: 3
Käyttöjärjestelmä: Windows 10 64-bittinen
Versio: vähintään 10 10.0.16299.15
Järjestelmäarkkitehtuuri: Intel Suoritinmallisto:6, Malli:14, Alaversio:3, MMX, SSE-kokonaislukutuki, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
Fyysisten prosessorien määrä: 4
Suorittimen nopeus: 2208 MHz
Sisäinen muisti: 16277 Mt
Muistia vapaana: 2 Mt
Photoshopin käytettävissä oleva muisti: 14352 Mt
Photoshopin käytössä oleva muisti: 70 %
Aliastasot: Ei käytössä.
Muokkauspaletti: Käytössä.
Highbeam: Käytössä.
Kuvan ruudun koko: 1024K
Kuvavälimuistin tasot: 4
Kirjasimen esikatselu: Keski
Tekstinkoostaja: latinalainen
Näyttö: 1
Näyttöalueen rajat: ylä= 0, vasen= 0, ala= 1080, oikea= 1920
OpenGL-piirto: Käytössä.
OpenGL, vanhojen grafiikkasuoritinten salliminen: Ei havaittu.
OpenGL-piirtotila: Lisäasetukset
OpenGL, normaalitilan salliminen: Tosi.
OpenGL, lisäasetusten salliminen: Tosi.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=2
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=1024
glgpu[0].GLName="Intel(R) HD Graphics 530"
glgpu[0].GLVendor="Intel"
glgpu[0].GLVendorID=32902
glgpu[0].GLDriverVersion="22.20.16.4771"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="Intel(R) HD Graphics 530"
glgpu[0].GLRendererID=6418
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\ki124994.inf_amd64_4d880b3eb8bd7056\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki124994.inf_amd64_4d880b3eb8bd7056\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki124994.inf_amd64_4d880b3eb8bd7056\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki124994.inf_amd64_4d880b3eb8bd7056\igd12umd64.dll"
glgpu[0].GLDriverDate="20170813000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 22.20.16.4771"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
clgpu[0].CLPlatformVersion="1.2"
clgpu[0].CLDeviceVersion="1.2 CUDA"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=2048
clgpu[0].CLName="GeForce 930MX"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="388.73"
clgpu[0].CLBandwidth=2.69677e+10
clgpu[0].CLCompute=187.734
clgpu[1].CLPlatformVersion="2.0 "
clgpu[1].CLDeviceVersion="2.0 "
clgpu[1].IsIntegratedCLGPU=1
clgpu[1].CLMemoryMB=6502
clgpu[1].CLName="Intel(R) HD Graphics 530"
clgpu[1].CLVendor="Intel(R) Corporation"
clgpu[1].CLVendorID=32902
clgpu[1].CLDriverVersion="22.20.16.4771"
clgpu[1].CLBandwidth=1.91102e+10
clgpu[1].CLCompute=144.806
Lisenssityyppi: Tilaus
Sarjanumero: x
GUIDBucket:
Sovelluskansio: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
Tilapäinen tiedostopolku: C:\Users\Siiri\AppData\Local\Temp\
Photoshop-työlevyllä on asynkroninen I/O käytössä
Työlevyt:
Käynnistys, 118.0G, 22.2G vapaa
Vaadittujen plug-inien kansio: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
Ensisijainen plug-in-kansio: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
Asennetut komponentit:
   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
   ACE.dll   ACE 2017/11/22-18:28:12   79.589342   79.589342
   AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
   AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
   AdobeOwl.dll   Adobe Owl   5.2.11
   AdobePDFL.dll   PDFL 2017/10/31-06:12:59   79.250229   79.250229
   AdobePIP.dll   Adobe Product Improvement Program   7.4.1.109.46827
   AdobeSVGAGM.dll   AdobeSVGAGM   79.588619   79.588619
   AdobeXMP.dll   Adobe XMP Core 2017/07/13-01:06:39   79.160924   79.160924
   AdobeXMPFiles.dll   Adobe XMP Files 2017/07/13-01:06:39   79.160924   79.160924
   AdobeXMPScript.dll   Adobe XMP Script 2017/07/13-01:06:39   79.160924   79.160924
   adobe_caps.dll   Adobe CAPS   10,0,0,6
   AGM.dll   AGM 2017/11/22-18:28:12   79.589342   79.589342
   ahclient.dll    AdobeHelp Dynamic Link Library   3.0.0.6
   AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
   amtlib.dll   AMTLib (64 Bit)   10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8)   1.000000
   ARE.dll   ARE 2017/11/22-18:28:12   79.589342   79.589342
   AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
   AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
   Bib.dll   BIB 2017/11/22-18:28:12   79.589342   79.589342
   BIBUtils.dll   BIBUtils 2017/11/22-18:28:12   79.589342   79.589342
   boost_date_time.dll   photoshopdva   11.1.0
   boost_filesystem.dll   photoshopdva   11.1.0
   boost_signals.dll   photoshopdva   11.1.0
   boost_system.dll   photoshopdva   11.1.0
   boost_threads.dll   photoshopdva   11.1.0
   cg.dll   NVIDIA Cg Runtime   3.0.00007
   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
   CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
   CoolType.dll   CoolType 2017/11/22-18:28:12   79.589342   79.589342
   CRClient.dll   Adobe Crash Reporter Client DLL   1.6.3.0
   dnssd.dll   Bonjour   3,0,0,2
   dvaaudiodevice.dll   photoshopdva   11.1.0
   dvacore.dll   photoshopdva   11.1.0
   dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
   dvamarshal.dll   photoshopdva   11.1.0
   dvamediatypes.dll   photoshopdva   11.1.0
   dvametadata.dll   photoshopdva   11.1.0
   dvametadataapi.dll   photoshopdva   11.1.0
   dvametadataui.dll   photoshopdva   11.1.0
   dvaplayer.dll   photoshopdva   11.1.0
   dvatransport.dll   photoshopdva   11.1.0
   dvaui.dll   photoshopdva   11.1.0
   dvaunittesting.dll   photoshopdva   11.1.0
   dynamiclink.dll   photoshopdva   11.1.0
   ExtendScript.dll   ExtendScript 2017/08/31-12:13:14   81.1150526   81.1150526
   icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   igestep30.dll   IGES Reader   9.3.0.113
   imslib.dll   IMSLib DLL   10.0.0.22
   JP2KLib.dll   JP2KLib 2017/10/31-01:22:04   79.268591   79.268591
   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
   libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
   libmmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
   LogSession.dll   LogSession   7.4.1.109.46827
   mediacoreif.dll   photoshopdva   11.1.0
   MPS.dll   MPS 2017/10/31-01:22:04   79.588396   79.588396
   pdfsettings.dll   Adobe PDFSettings   1.04
   Photoshop.dll   Adobe Photoshop CC 2018   19.1.3
   Plugin.dll   Adobe Photoshop CC 2018   19.1.3
   PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   8.5.0
   PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   8.5.0.87
   PSArt.dll   Adobe Photoshop CC 2018   19.1.3
   PSCloud.dll                                                   1.0.0.1
   PSViews.dll   Adobe Photoshop CC 2018   19.1.3
   SCCore.dll   ScCore 2017/08/31-12:13:14   81.1150526   81.1150526
   SVGRE.dll   SVGRE   79.586793   79.586793
   svml_dispmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
   tbb.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
   TfFontMgr.dll   FontMgr   9.3.0.113
   TfKernel.dll   Kernel   9.3.0.113
   TFKGEOM.dll   Kernel Geom   9.3.0.113
   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
   updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
   VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
   VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
   WinRTSupport.dll   Adobe Photoshop Windows RT Support   19.0.0.0
   WRServices.dll   WRServices Thu June 21 2017 12:26:24   Build 0.22473   0.22473
   wu3d.dll   U3D Writer   9.3.0.113
Vaaditut plug-init:
   3D Studio 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “U3D.8bi”
   Aalto 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Allemaalaus 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Alue 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “statistics.8ba”
   Älykäs sumennus 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Aukaisu 19.1.3 - tiedostosta “Filter Gallery.8bf”
   BMP 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Camera Raw 10.3 - tiedostosta “Camera Raw.8bi”
   Camera Raw -suodin 10.3 - tiedostosta “Camera Raw.8bi”
   Cineon 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “Cineon.8bi”
   Collada 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “U3D.8bi”
   CompuServe GIF 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Dicom 19.1.3 - tiedostosta “Dicom.8bi”
   Diffuusiohohde 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Eazel Acquire 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “EazelAcquire.8ba”
   Entropia 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “statistics.8ba”
   Erottavat pilvet 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “Clouds.8bf”
   FastCore-rutiinit 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “FastCore.8bx”
   Filmin rakeisuus 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Flash 3D 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “U3D.8bi”
   Fresko 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Google Earth 4 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “U3D.8bi”
   Graafinen kynä 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Halide Bottlenecks 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “HalideBottlenecks.8bx”
   Halkeamat 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Hankaustikku 19.1.3 - tiedostosta “Filter Gallery.8bf”
   HDRMergeUI 19.1.3 - tiedostosta “HDRMergeUI.8bf”
   Hehkuvat reunat 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Hiili 19.1.3 - tiedostosta “Filter Gallery.8bf”
   HSB/HSL 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Huipukkuus 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “statistics.8ba”
   IFF-muoto 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   IGES 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “U3D.8bi”
   JPEG 2000 19.1.3 - tiedostosta “JPEG2000.8bi”
   Karkeat pastellit 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Keskiarvo 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “Average.8bf”
   Keskipoikkeama 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “statistics.8ba”
   Keskiverto 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “statistics.8ba”
   Kiteytä 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   KomentosarjojenTuki 19.1.3 - tiedostosta “ScriptingSupport.8li”
   Korostetut reunat 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Kromi 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Kuidut 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Kuiva sivellin 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Kuvanpakkaussuodin 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “ChannelPort.8bf”
   Lasi 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Leimasin 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Liitu &ja hiili 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Linssiheijastus 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Linssikorjaus 19.1.3 - tiedostosta “Lens Correction.8bf”
   Linssisumennus 19.1.3 - tiedostosta “Lens Blur.8bf”
   Matlab Operation 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “ChannelPort.8bf”
   Mediaani 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “statistics.8ba”
   Meren väreily 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Mezzotinto 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Mittausydin 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “MeasurementCore.8me”
   MMXCore-rutiinit 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “MMXCore.8bx”
   Moniprosessoinnin tuki 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “MultiProcessor Support.8bx”
   Mosaiikkiruudut 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Muistilappu 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Mukautuva laajakulma 19.1.3 - tiedostosta “Adaptive Wide Angle.8bf”
   Muodosta värihaun ruudukko 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “Export3DLUT.8be”
   Muovipakkaus 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Musteääriviivat 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Napakoordinaatit 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Neonvalo 19.1.3 - tiedostosta “Filter Gallery.8bf”
   NTSC-värit 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “NTSC Colors.8bf”
   OpenEXR 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Paina kuopalle 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Pakopiste 19.1.3 - tiedostosta “VanishingPoint.8bf”
   Palettiveitsi 19.1.3 - tiedostosta “Filter Gallery.8bf”
   PCX 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “PCX.8bi”
   Pesusieni 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Photoshop 3D -ohjelma 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “Photoshop3DEngine.8bi”
   Photoshop Touch 19.0 - tiedostosta “PSDX.8bi”
   Pienin arvo 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “statistics.8ba”
   Pilvet 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “Clouds.8bf”
   Pintakuviot 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Pistemaalaus 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Pixar 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “Pixar.8bi”
   PLY 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “U3D.8bi”
   Poikkeuta 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Poista lomitus 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Porrasta reunat 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Portable Bit Map 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “PBM.8bi”
   PRC 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “U3D.8bi”
   Pullista 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Pursota 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Pyöräytä 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Radiance 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “Radiance.8bi”
   Rajaa ja suorista valokuvia 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “CropPhotosAuto.8li”
   Rajaa ja suorista valokuvia -suodin 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Rakeisuus 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Rappaus 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Rasterikuvio 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Reitit Illustratoriin 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Reliefi 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Revityt reunat 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Ristiviivoitus 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Roiskutus 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Ruudut 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Säteittäinen sumennus 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Sävytetty lasi 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Siksak 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Solarisaatio 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “Solarize.8bf”
   Spaces 19.1.3 - tiedostosta “Spaces.8li”
   STL 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “U3D.8bi”
   Suihkeviivat 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Sulata 19.1.3 - tiedostosta “Liquify.8bf”
   Sumi-e 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Summa 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “statistics.8ba”
   Suodinvalikoima 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Suurin arvo 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “statistics.8ba”
   Taivuta 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Tallenna Webiä varten 19.1.3 - tiedostosta “Save for Web.8be”
   Targa 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Tärinän vähennys 19.1.3 - tiedostosta “Shake Reduction.8bf”
   Tilkkutäkki 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Töherrys 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Tummat viivat 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Tuuli 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   U3D 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “U3D.8bi”
   Valokopio 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Väreily 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Varianssi 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “statistics.8ba”
   Värikynä 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Väriliidut 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Värirasterointi 19.1.3 - tiedostosta “Standard MultiPlugin.8bf”
   Verkko 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Vesipaperi 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Vesiväri 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Vie värihaun taulukot 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “Export3DLUT.8be”
   Vinot viivat 19.1.3 - tiedostosta “Filter Gallery.8bf”
   Vinous 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “statistics.8ba”
   Virtuaalitodellisuuden kuvauskieli | VRML 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “U3D.8bi”
   Wavefront|OBJ 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “U3D.8bi”
   WIA-tuki 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “WIASupport.8li”
   Wireless Bitmap 19.1.3 (20180323.r.293 2018/03/23: 1163761) - tiedostosta “WBMP.8bi”
Valinnaiset ja muiden ohjelmien plug-init: EI YHTÄÄN
Päällekkäiset ja käytöstä poistetut plug-init: EI YHTÄÄN
Plug-init, joiden lataaminen epäonnistui: Ei yhtään
Laajennukset:
   com.adobe.inapp.purchase  2.11.27 - tiedostosta “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
   com.adobe.Butler.backend  2.0.0 - tiedostosta “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
   Kirjastot  2.11.27 - tiedostosta “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
   Uusi dokumentti  2.1.1 - tiedostosta “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_CMDN_EXTENSION_2_1_1_004\fnft.html”
   Aloita  2.1.1 - tiedostosta “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_2_1_1_076\index.html”
   Adobe Color -teemat  6.1.0 - tiedostosta “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
   Vie muodossa  3.1.2 - tiedostosta “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Asennetut TWAIN-laitteet: Ei yhtään
Votes
Translate
Translate
Report
Report
New Here ,
Thanks a lot Dave...you are a life saver
Votes
Translate
Translate
Report
Report
New Here ,
Apr 21, 2018 Apr 21, 2018
The text file worked great, thankyou sooo much
Votes
Translate
Translate
Report
Report
New Here ,
Apr 22, 2018 Apr 22, 2018
I use a surface Pro 3 to draw, which means I draw on the screen, and not a tablet, but I am experiencing the same issues as above.. what can I do to fix this??
Votes
Translate
Translate
Report
Report
Community Expert ,
For the Surface Pro - try the registry fix from Microsoft in the link below :
April 10, 2018—KB4093112 (OS Build 16299.371)
Dave
Votes
Translate
Translate
Report
Report
Guest
Votes
Translate
Translate
Report
Report
