Hi, the pictures appearing in the Library module are correctly exposed, but when I look at them in the Development module they get way darker. When exported, the pucture looks like it should be (eg as in Library). How can I fix this ? I've been using LR for years and suddenly this happened. The rest of the screen is fine, it is just the picture. Thanks.
As it appears in Library (print screen)
As it appears in Development (print screen)
HELP.
Probably a corrupt display profile.
Please check you display profile as described here: https://www.lightroomqueen.com/how-do-i-change-my-monitor-profile-to-check-whether-its-corrupted/
Hello, thanks for the prompt answer. it seems to be working now, many thanks!
It's weird how it only affects the image and not the rest of the screen though but I'm not technical guy.
Would you know if I need to recalibrate my screen as my former profile (which was calibrated with i1 Display Pro) is no longer working properly?
You should re-calibrate your display on a regular basis since it changes over time.
