How to rotate this image in circle Means on it axis like
It's not clear what you mean. You need to explain better.
Mylenium
I want to rotate this image like a chain. Hope this is clear now like rotating circle
In after effects a layers "axis" is called the Anchor Point.
You use the Pan Behind Tool to move the Anchor point where you want it to be & then animate the Rotate property.
If you're asking how to rotate all the little boxes around the center point as if it were a 3D rotating chain....?
You can't do that with flat 2D image.
