4 Replies Latest reply on Apr 12, 2018 10:41 PM by Sajid Attar
    Star Shining Effect
    Sajid Attar Level 1
      Hi All
      can anyone help me to create the effect like below.
      SajidAttar
        • 1. Re: Star Shining Effect
          macpawel Adobe Community Professional
          You can use brush to prepare similar effect.
          Just find brush (assorted Brushes, Natural brushes, legacy brushes folder) with radiuses and click once to prepare star - you can use it some times
          Then use  another circular brush to add glow effect
          pawel
          • 2. Re: Star Shining Effect
            master mo Adobe Community Professional
            This tutorial should help.
            Photoshop Tutorial :: Exploding Star - YouTube
            Good luck
            • 3. Re: Star Shining Effect
              davescm Adobe Community Professional
              Hi
              Start with a black background and on a new layer make a circle in the centre with a soft brush and then enlarge the brush, reduce the opacity slightly, and make a lighter soft circle
              Add a new layer and set brush symmetry to New Dual Axis
              Go to the paths panel and change the name of the path to Radial Symmetry 10
              On a new layer add a single stroke from the centre outwards. The brush symmetry will make that 10 radiating strokes. Note if you are not using a pen & tablet pressure to control the width and the opacity then go to the brush panel and set the Size and opacity controls to Fade.
              Repeat the above a few times on new layers , each time changing the path name to say Radial Symmetry 8, or Radial Symmetry 3 to vary the number of radial strokes (the number can be between 2 and 12)
              Finally you can adjust the opacity of the radial layers and transform rotate each to get the effect you want
              I hope that helps you
              Dave
              • 4. Re: Star Shining Effect
                Sajid Attar Level 1
                Thank you so much you all, this helped me a lot.
