Hello, i have a funny problem with a Wacom Cintiq 22HD
IT works regularly but as i zoom the image and the sliders appear, the vertical movement of the pen would move the picture up and down, while the horizontal works regularly... This is very strange ....
As i zoom out, the pen works again regularly. Any ideas?
UPDATE
when i disable Windows INK i hv no problems while the picture is zoomed, but i don't have the pressure recongized.
If i re-enable Windows INK, i have pressure but when the picture is zoomed, Photoshop will make the vertical slide move when using the pen vertically.
Hello, users with the scroll issue should apply this fix : Cannot paint with stylus when zoomed in on image | Windows 10
Hi
Please search before posting - this problem has been answered several times today .
The latest windows update (KB4093112) has caused an issue with the Wacom tablet and Photoshop.
You can either - undo the update
or
Do the following (recommended) :
1. Use notepad to create a text file and type in :
UseSystemStylus 0
2. Save the file as PSUserConfig.txt in the following location
C: > Users > Username > AppData > Roaming > Adobe > Adobe Photoshop CC 2018 > Adobe Photoshop CC 2018 Settings
3. Go to the tablet properties and uncheck "Use Windows Ink"
4. Restart Photoshop
That is it - all should now work well (you need to do all the above steps to retain pen pressure)
Note : There is a third option. Microsoft made this change intentionally and they have issued a way round it with registry change (see link below). However for Photoshop the PSUserConfig method works.
https://www.reddit.com/r/Windowsink/comments/8508fi/controlling_pen_behavior_in_windows_10 /
Note 2 : If you have another version of Photoshop installed e.g. CC2017 then you will need to add the file to the CC2017 folders
Dave
thank you for your answer guys, that was my last option as our workers told me they got a windows update, so i just removed that update... believe me i googled everywhere and i couldn't find that solution, so by thinking i got there myself.
Thanks for your help
