4 Replies Latest reply on Apr 12, 2018 8:22 AM by jamesm85745938
    Faulty import of .mov from Canon 70D
    jamesm85745938 Level 1
      Premier Pro Version 12.1 Build 186
      I have had no success in importing .mov files shot on a Canon 70D.
      The result is a miss-scanned mess shaded green and purple.
      The files play perfectly in VLC, SMPlayer and Windows Media Player. Media Info shows that it is an MP-4 container with the following video section:
      Video
      Format                                   : AVC
      Format/Info                              : Advanced Video Codec
      Format profile                           : High@L4.1
      Format settings, CABAC                   : No
      Format settings, RefFrames               : 2 frames
      Format settings, GOP                     : M=3, N=12
      Codec ID                                 : avc1
      Codec ID/Info                            : Advanced Video Coding
      Duration                                 : 26 s 480 ms
      Bit rate                                 : 28.9 Mb/s
      Width                                    : 1 920 pixels
      Height                                   : 1 080 pixels
      Display aspect ratio                     : 16:9
      Frame rate mode                          : Constant
      Frame rate                               : 25.000 FPS
      Color space                              : YUV
      Chroma subsampling                       : 4:2:0
      Bit depth                                : 8 bits
      Scan type                                : Progressive
      Bits/(Pixel*Frame)                       : 0.557
      Stream size                              : 91.1 MiB (95%)
      Language                                 : English
      Encoded date                             : UTC 2018-04-12 10:39:57
      Tagged date                              : UTC 2018-04-12 10:39:57
      Color range                              : Full
      Color primaries                          : BT.709
      Transfer characteristics                 : BT.709
      Matrix coefficients                      : BT.709
      Has anyone any ideas?
