0 Replies Latest reply on Aug 21, 2008 2:59 PM by M_Kujawa
    Runtime Sharing = missing classes in debugger
    M_Kujawa
      (Flash CS3 v9.0)
      I created three FLAs, Test1.fla, Test2.fla, and TestAll.fla. They are set for Player 8, ActionScript 2. Test1.fla has a symbol, Test1 which is exported for ActionScript, frame 1, runtime sharing, and using class Foo. Test2.fla has a smbol, Test2, which is exported for ActionScript, frame 1, runtime sharing, and using class Foo.TestAll.fla imports Test1 and Test2 and has them on the stage at frame 1.
      Foo extends MovieClip and has a constructor that traces a line of text and an onRelease that traces a line of text. When I run TestAll.swf, I see both objects. However, only one of the contrscutor trace lines is output, and only one of them interracts with the mouse. If I drag out another instance of each symbol, both new instances work (so three of four are working.) However, in the stand-alone flash player (ie if I double-click the swf), it works as I expect.
      It seems like, in the debugger, the first swf on a layer to import the shared class always loses.
      Am I doing something wrong? Is there an established work-around for this?
