Aloha insane coders.
I am finalizing an interface and would like to know if it is possible to add an eventListner so that by pressing the "Enter / Return" button the action of the button is also executed. This makes the use of the interface more intuitive. Every time I try to intuitively do this ... when I test the interface.
Another question is if I can put an event listner in the area of a panel where the content is controlled by a scrollbar. When I use the mouse scrollbutton on top of the scrollbar the button works, but I would like to be able to add an eventlistner when the mouse is over the content too, plus the scrollbar is very slow when using the mouse scrollbutton.
I am not finding any documentation about it.
Thanks in advance for your support ...
Rubens
Two options regarding the Enter Button:
Easiest solution: If you just assign "name: ok" - this will execute the button on enter by default.
var myButton = pal.add("button", undefined, "Enter", {name: "ok"});
If you want to use the event listener: This only works, if the button is active. You can do this via an event listener and doing the false / true trick.
...function handle_key(key, control){
switch (key.keyName)
case "Enter":
key.preventDefault();
// do stuff
break;
defau
Here is hopefully a start for the keydown event listener.
w.addEventListener ("keydown", keyPressHandler); // Add event "keydown" to whatever and have it call a function
function keyPressHandler (ev){ // ev contains information sent by the EventListener
if(ev.type == "keydown" && ev.keyName == "Enter"){
p.preventDefault(); // If I have this right, this makes sure that the event is only executed once
// Add whatever you want to happen here
I'm not sure about the scrollbar. I'm pretty sure extendscript does not listen for direction of the scroll wheel. It can tell it's moving but not in what directions, which is pretty useless imo. If I'm wrong about that I would love to know because the scroll wheel could be super useful in UI stuff.
Hey Dash... thanks for your help, but this addEventListner is not working for me.
case "Enter":
// do stuff
break;
default:
return;
var mouseEventHandler = function(ev){
if(ev.type == 'mouseover'){
myButton.active = false;
myButton.active = true;
myButton.addEventListener('mouseover', mouseEventHandler);
myButton.addEventListener("keydown", function(k){handle_key(k, this);});
Thank you so much, ILJI
It's Working Now, but I have to put the event listener into the editText the user is forced to fill.
As I'm using an iconButton this still not working, I don't know why.
If you have a solution to iconButtons with multiple image instances. I would love to hear.
Cheers.
Rubens Nobre.
Okay, when you have the listeners on the editText now, the "enter" will trigger your defined action. What do you need now exactly - to have the button react to pressing "enter", even if the editText is not active? For this case, you would just need to make sure that some other (or all) object gets activated on mouseover or mousemove and have that object have the key event listener applied to as well. The stuff which happens, when hitting enter could also change the button state/button image, if that is what you are aiming for.
Cheers.
