• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
An issue with Photoshop or possibly something outside of Photoshop but it involves Photoshop
New Here ,
Apr 13, 2018 Apr 13, 2018
My problem is one of which I have never encountered before.
and is rather simple but completely makes photoshop unusable for me.
running on a Surface, every time I use the pen, all the tools do the exact same thing. The pen tool, eraser, magnifying lens. all of them.
they scroll the image. every single one of the tools does nothing but scroll the image.
As demonstrated below, using the Surface pen.
I am unsure if this is a problem with Photoshop itself or something with the computer settings but either way,
its good to have a solution out there in the event someone else has the same problem
Views
274
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , May 08, 2018 May 08, 2018
Hello, the easiest solution is to apply this update : Cannot paint with stylus when zoomed in on image | Windows 10
Votes
Translate
Translate
Adobe
LEGEND ,
Seems to be a very common problem with most recent update to Windows. Check this thread for possible fixes.
Brush acting like move tool??
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi
The latest windows update (KB4093112)  has caused an issue with the Wacom tablet and Photoshop.
You can either - undo the update
or
Do the following (recommended) :
1. Use notepad to create a text file and type in :
UseSystemStylus 0
2. Save the file as PSUserConfig.txt in the following location
C: > Users > Username > AppData > Roaming > Adobe > Adobe Photoshop CC 2018 > Adobe Photoshop CC 2018 Settings
3. Go to the  tablet properties and uncheck "Use Windows Ink"
4. Restart Photoshop
That is it - all should now work well (you need to do all the above steps to retain pen pressure)
Note : There is a third option. Microsoft made this change intentionally and they have issued a way round it with registry change (see link below). However for  Photoshop the PSUserConfig method works.
https://www.reddit.com/r/Windowsink/comments/8508fi/controlling_pen_behavior_in_windows_10 /
Note 2 : If you have another version of Photoshop installed e.g. CC2017 then you will need to add the file to the CC2017 folders
Dave
Votes
Translate
Translate
Report
Report
New Here ,
Apr 14, 2018 Apr 14, 2018
Thanks for the help, seems the third option works for me, sorta. after all, I did specify that I was running a Surface, not Wacom.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Votes
Translate
Translate
Report
Report
