• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Wacom pro pen 2 problems for photoshop
New Here ,
Apr 13, 2018 Apr 13, 2018
Ok There's probably an easy fix to this. I use a Wacom Mobilstudiopro and a pro pen 2 for photoshop. It was working fine until this morning. To actually draw in the program I have to hold the second button down on the pen to actually write. If I don't it just moves the paper around. It's really frustrating and I'm sure there's an easy solution. Where in settings can I switch it so I don't have to hold that second button down just to draw?
Views
486
Translate
Translate
Report
Report
Community guidelines
community guidelines
Deleted User
Apr 14, 2018 Apr 14, 2018
Hi
You have two options to fix this try either one
1. Use notepad to create a text file and type in :
# Use WinTab
UseSystemStylus 0
2. Save the file as PSUserConfig.txt in the following location
C: > Users > Username > AppData > Roaming > Adobe > Adobe Photoshop CC 2018 > Adobe Photoshop CC 2018 Settings
3. Go to the Wacom tablet properties and for Photoshop under Mapping  uncheck "Use Windows Ink"
Or
1 Select everything inside the quotes here (don't include the quotes): “reg add HKEY_CURRENT_USER\Softw
Votes
Translate
Translate
Adobe
Guest
LATEST
Hi
# Use WinTab
UseSystemStylus 0
Or
1 Select everything inside the quotes here (don't include the quotes): “reg add HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Pen /v LegacyPenInteractionModel /t REG_DWORD /d 1 /f”
2 Copy it with Ctrl + C on the keyboard.
3 Type Windows Key + X (together), a menu will appear
4 Then type "A" on the keyboard. That will give you an elevated administrator PowerShell command prompt.
5 Paste the command you copied into that window with Ctrl + V
6 Hit "Enter" on the keyboard
7 Reboot
If you use the first one you may need to enable hidden items
Votes
Translate
Translate
Report
Report
