5 Replies Latest reply on Apr 15, 2018 12:25 PM by visler
    Photo shows up wrong in lightroom
    visler Level 1
      I have recently few times seen photo looking sort of corupt in LRScreenHunter_08 Apr. 15 10.15.jpg
      If I open same raw file in photoshop camera raw it looks okScreenHunter_09 Apr. 15 10.15.jpg
      (Photos are by purpose underexposed to keep iso down,)
      All should be newest versions
      Any hints on how I can fix this ?
        • 1. Re: Photo shows up wrong in lightroom
          dj_paige Level 10
          The photo file has become corrupted somehow. The only known causes of this are hardware malfunction somewhere. It could be the hard disk is sending the wrong information to Lightroom, or memory, or even bad camera card or error in transfer from camera to computer. You need to try importing these photos again using different hardware (different transfer hardware, different hard disk) to see if you can isolate the problem.
          • 2. Re: Photo shows up wrong in lightroom
            visler Level 1
            If i open the excact same file using photo the problem is not there.. this is somehow LR having the problem
            • 3. Re: Photo shows up wrong in lightroom
              JohanEl54 Adobe Community Professional
              Is that really the same file you open in Camera Raw? Or is it a copy? This does look like file corruption, but if the same file opened in Camera Raw does not show this, then obviously this can't be corruption. What happens when you choose 'Library - Previews - Build Standard-sized previews' with this file selected?
              • 4. Re: Photo shows up wrong in lightroom
                dj_paige Level 10
                It could be the disk is sending the wrong information to LR, or memory issues.
                As stated, the only known cause of this type of corruption is hardware malfunctions, you need to incorporate this into your thinking, and then do some testing to diagnose the problem.
                If you are looking for a "switch" or option in LR to make the problem go away, there is none (because it is not a Lightroom problem).
                Also, as JohanEL54 said, it could be just a bad preview file that got corrupted somehow, but the cause of the corruption still needs to be identified and eliminated, or it will keep coming back.
                • 5. Re: Photo shows up wrong in lightroom
                  visler Level 1
                  The file i open in LR and photoshop is excactly the same file, and a normal copy on a pc makes sure data is ok in the new copy as part of the copying procedure.
                  But thanks for the feedback here.
