This content has been marked as final.
Show 4 replies
1. Re: Outer Bevel Opacity Problems
Jeff Arola Apr 15, 2018 11:34 AM (in response to bionicdance)What are the settings for the Contour and Gradient Overlay?
2. Re: Outer Bevel Opacity Problems
bionicdance Apr 15, 2018 11:36 AM (in response to Jeff Arola)Actually, I may have figured it out...needed to use Stroke as well.
Seems an odd requirement, but...it worked.
Felt like a kludge, but it was a solution, neh?
3. Re: Outer Bevel Opacity Problems
norman.sanders Apr 15, 2018 12:08 PM (in response to bionicdance)If you go to Layers > Layer Style > Create Layers, it will create separate layers of the Outer Bevel Highlight from the Outer Bevel Shadow. If you turn off the eye on all the layers except the Outer Bevel Shadow it will reveal each bevel as a group as a tint and as such will show the red color beneath.
4. Re: Outer Bevel Opacity Problems
bionicdance Apr 15, 2018 12:12 PM (in response to norman.sanders)Well, okay the idea was to get rid of the red, not bring it out.
Also, I found the solution.
But, thanks.
