1 Reply Latest reply on Apr 15, 2018 10:52 PM by Bob Somrak
    Turning on and off Individual Tone Curve Channels?
    southwestform Level 1
      When working with the Tone Curve there seems to be one switch that either turns on the effect or turns it off for whatever is done to the RGB, R,G,and B channels. I want to be able to make changes to each individual channel and go back to see how it looked prior to working in that channel. So perhaps I work on the RGB channel and then make changes to the G channel and I want to turn off the G channel but still keep the RGB changes turned on. Is there a way to do this?
      Thanks in advance.
        • 1. Re: Turning on and off Individual Tone Curve Channels?
          Bob Somrak Level 6
          You could make a preset called ZeroRED for instance by creating a tone curve preset with all the RGB at default or as you say OFF
          Then hand edit the tone curve section of the preset like this by getting rid of all the curve data except RED.  Create two more for Green and Blue.   To turn off the RED channel just place your cursor on the ZeroRED preset but don't press it and the preview will show what you want.     Not great but I tried it and it seems to work;
          Before
          After
