3 Replies Latest reply on May 27, 2018 7:24 AM by AnandSri
    PDF 显示乱码
    FZY
      下面是它原本的样子:
      不过,由于论坛限制,我暂时不能将出问题的 PDF 直接上传。
        • 1. Re: PDF 显示乱码
          surajs83341789 Level 1
          Please add translated pdf of this question or give some hint.If you are looking for help related to  Epson Printer Support
          I can help you with it.
          • 2. Re: PDF 显示乱码
            FZY Level 1
            Translation (by Microsoft Translator):
            This is the PDF document.
            Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
            Try opening this document with Adobe Acrobat Reader and Microsoft Edge, and you'll find that the display is different.
            Sorry, my English is not very good, so I can not directly use English reply.
            Original Text:
            这里是 PDF 文档。
            试着使用 Adobe Acrobat Reader 和 Microsoft Edge 打开这个文档,你会发现显示的内容不一样。
            抱歉,我的英文不是很好,所以不能直接使用英文回复。
            • 3. Re: PDF 显示乱码
              AnandSri Adobe Employee (Admin)
              Hello FZY,
              Sorry for the delayed response and inconvenience caused. Please make sure that you have the latest Adobe Reader DC installed, check for any pending updates from help>check for updates, reboot the machine after installing the updates and see if this brings any difference.
              Navigate to Adobe Reader's Preferences and go to the "Page Display" category. Now toggle the "Use local fonts" under Rendering setting. Does that make a difference?
              Make sure that you have all the required Fonts installed in the system, this is very likely a problem with how the font is embedded in the PDF file. Just because it worked in Edge, does not necessarily mean that it cannot be such a problem: The new version of Acrobat/Reader may just be interpreting the PDF standard more tightly as the required Fonts are not embedded in the PDF.
              How does this PDF was originally created? Most times, associated with the use of non-standard encoding for the fonts used in the PDF or the use of fonts (and associated encoding)in the PDF that are not on the end-user local machine can cause this issue.
              If this PDF is created by a third party application, it seems that the PDF originator failed to use an adequate PDF producer.
              You may want to bring the issue up with the PDF originator and see if they can provide you the fonts which can be installed or ask them to embed the font in the original PDF.
              Let us know how it goes and share your findings.
              Regards,
              Anand Sri.
              2 people found this helpful
