5 Replies Latest reply on Apr 18, 2018 9:19 AM by Dave__M
    Searchable PDF
    lorik47260675 Level 1
      We have Adobe Acrobat Pro DC. We currently save our invoice payments in a PDF using the transaction number as the file name. (i.e. GAX 18_9999). How can I tag these or make them searchable so that when I type in a vendor name, all the pdfs associated with that vendor appear?
        • 1. Re: Searchable PDF
          Dave__M Adobe Community Professional
          I'm not sure I completely understand your need/scenario, but perhaps by adding the vendor name into the file's metadata or keyword list, it could be a way.  If you go to a PDF's properties (File>Properties, or cmd/ctrl D, you can enter keywords or other meta data there.  You'd need to save the file after adding the metadata.
          I hope this is helpful.
          My best,
          Dave
          • 2. Re: Searchable PDF
            Hi Dave,
            Thanks for the information, I tried this, but when I did a search in Adobe, there were no results found. I'll keep trying. I'm sure there is a way. When I did a google search, I found information about adding a tag. Tried that also and not having any luck. Maybe I'm missing a step.
            Lori
            • 3. Re: Searchable PDF
              Maybe a bit more information might be helpful.
              Where/what are you using for your searching?  Are you using Acrobat's Find or Search function, or are you in your operating system and trying to search a specific folder?  Also, what is your operating system?
              My best,
              Dave
              • 4. Re: Searchable PDF
                I think I may have solved this. Looks like I can open Adobe and go to edit/advance search and fill in the information and it will find all the files that contain what I am looking for. A couple didn't pull so I put the information in the metadata section and they showed up.
                I think I just wasn't searching properly.
                Thanks for your help.
                • 5. Re: Searchable PDF
                  Great - that is precisely the direction I was going to point you!  The Search feature is very powerful, and most people only seem use Find, which is considerably less capable, IMHO.
                  My best,
                  Dave
